BIMMERPOST Universal Forums > Off-Topic Discussions Board > Garage Makeover
      07-28-2020, 11:46 PM   #45
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by monkeyjuice5150 View Post
I recommend not going with race deck, or plastic tiles. Learned my lesson. Tossed them out after 2 years.
i've had part of my garage done with Racedeck. no issues after a year of usage. just finished the whole garage this week. can you elaborate?
Originally Posted by 9M71 View Post
Subscribed, love garage build threads.
Opposite experience for me, although i went with swisstrax over racedeck (had samples of both). Going 2 years now and no regrets. Color matters - lighter colors will stain regardless of bran. No issues with constant wrenching either, those tiles can take a beating.
agree! i used my jack and stands on top of it with no issues. they can take a beating. my neighbor has the Swisstrax and they both look the same to me other than the Swisstrax was larger
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
tcphoto3531.00
      08-01-2020, 11:34 PM   #46
ferraricare
Drives: 2016 M235i
2016 M235i  [0.00]
Garage Makeover Update
Floor epoxy paint complete! Moving in Tuesday...
Appreciate 6
3798j11406.00
overcoil3073.50
tcphoto3531.00
mcvaughan704.00
King Rudi13154.00
      08-02-2020, 07:02 AM   #47
3798j
3798j's Avatar
11406
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Floor looks great and think it's a perfect "fit" for the aged wood walls...going to be a bear of a challenge finding that dropped 8mm washer though.
wdb4721.50
King Rudi13154.00
      08-02-2020, 07:48 AM   #48
wdb
dances with roads
wdb's Avatar
4722
Drives: '07 E86, '02 996, '95 Seven
Good point! Hopefully it's magnetic.
      08-02-2020, 11:45 AM   #49
Kolyan2k
Drives: 2006 S2000
Thats better than my living room
overcoil3073.50
King Rudi13154.00
      08-07-2020, 06:37 PM   #50
ferraricare
Drives: 2016 M235i
2016 M235i  [0.00]
Garage Makeover Latest Update
Here's some pictures from move in day: tiles went well enough I'm now considering doing the second bench area. Epoxy paint looks fantastic.
Appreciate 5
wdb4721.50
3798j11406.00
overcoil3073.50
MKSixer34184.50
      08-26-2020, 01:39 PM   #51
ferraricare
Drives: 2016 M235i
2016 M235i  [0.00]
Old Garage Makeover Latest 10/1/20
[IMG]undefined[/IMG]
      08-26-2020, 01:43 PM   #52
Joekerr
7929
Drives: 2017 Audi S6
Picture is "undefined" - didn't come through.
      08-26-2020, 01:46 PM   #53
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Great bones, for sure. If I were you, I'd create a journal to document your progress on garagejournal.com, as well.
Like some others who have chimed in here, I went with plastic tiles (Swisstrax) for my setup:
They can certainly take a beating and they hide all the dirt that falls to the ground and would normally be seen, so the flooring always appears clean. I will say you have to be careful with the type of jack and jackstands you use. Jacks with wider wheels (for better weight dispersion) and jack stands with flat bottoms (as opposed to angled, sharp edges) work better with this type of flooring.
That said, I have a bunch of extra tiles so if and when tiles get damaged, I can easily swap them out!
'05 BMW M3 6MT (Weekend car)
Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link!
3798j11406.00
nyalpine907433.00
      08-26-2020, 02:20 PM   #54
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Like some others who have chimed in here, I went with plastic tiles (Swisstrax) for my setup:<snip>
Did you have any problems w/the Swisstrax lip even w/the concrete lip? They suggested that I move the tiles back ~ 2" from the concrete lip.
      08-26-2020, 02:23 PM   #55
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Are you referring to the footing around the perimeter of the garage? Or the lip of the entrance of the garage where it meets the asphalt driveway?
Either way, I should have left more room (1/2" or so would have been enough) between the tiles and the back wall of the garage. Instead, I went right up against the footing. With the heat from the unusually warm summer we've had, some of the rubber tiles (I went with rubber in front of my workbench for comfort reasons) are bunching up because of expansion.
I'm going to trim back some of the tiles in the fall to allow that 1/2" or so of room that Swisstrax recommended (and I ignored) for expansion/contraction.
omasou2088.00
      08-26-2020, 02:26 PM   #56
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I was referring to the entrance. Thanks.
      08-26-2020, 02:28 PM   #57
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Ah, nope, I have the Swisstrax edge pieces right up against the lip. You can see it in these photos.
omasou2088.00
Spgm563.00
      08-26-2020, 02:35 PM   #58
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Thanks! That is EXACTLY what I was planing to do. That was until I read this post and talked to Swisstrax about it. They suggested to move the tiles back 2" so that the tires did not push the tiles back and snap them.
But seeing how it worked out for you, I'm going back to my original plan.
https://www.garagejournal.com/forum/...reak&showall=1
Only guy that I have seen having this many issues See post #12...
      08-27-2020, 12:21 AM   #59
ferraricare
Drives: 2016 M235i
2016 M235i  [0.00]
Here's some current shots: TV in, tiles finished and shop carpet for bench.
wdb4721.50
overcoil3073.50
MKSixer34184.50
      08-27-2020, 07:39 AM   #60
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
That link doesn't work for me.
      08-27-2020, 08:49 AM   #61
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I accidentally copied the shorten version from a previous post.
Link updated.
      08-27-2020, 08:53 AM   #62
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Link updated.
Ah, ok, interesting. Yeah, no problems here. Not sure if he's using the same edge pieces that I went with, but I haven't had any issues with pulling vehicles into/out of the garage:
Another option for those who need to account for a more robust transition would be something like this:
      08-27-2020, 08:55 AM   #63
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Oh and should anyone ever decide they want to purchase Swisstrax flooring (or anything that Obsessed Garage offers), Obsessed Garage offers very competitive pricing. And not for nothing, I get 5% commission if someone orders anything using the affiliate link in my sig.
Just throwing that out there.
      08-27-2020, 12:09 PM   #64
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
FYI. Obsessed Garage pricing is good pricing and equivalent to Swisstrax 20% + Free Shipping.
      08-27-2020, 12:12 PM   #65
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Exactly! I'm not just trying to push my agenda....I wouldn't vouch for them if I didn't believe in them!
      10-09-2020, 06:21 PM   #66
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
looking into getting interlocking tiles, is swisstrax pricey???
