BMW M2 Forum > BMW M2 Discussions > 2018 M2 OG Cranking not starting issue
      11-05-2023, 07:08 PM   #1
Grgstudios
Drives: E93 LCI 330d & 330i
Any ideas where I should check? Swapped battery and checked front and rear fuse boxes. Plugged scanner in and was getting fuel pressure (14kpa - is this okay?)
Car was in an accident however no bags deployed and the car cranks therefore ruling out the pyrofuse being blown.
See Video
video
      11-05-2023, 11:02 PM   #2
F87source
F87source's Avatar
Drives: Bmw M2
See Video
video
Fuel pressure is really really low. My car retains ~98 psi with the car off, so your fuel pump(s) might be dead - likely the LPFP since the HPFP on these cars are pretty stout. So I would check the LPFP, and I suspect it is not allowing the car to prime the fuel rail.
      11-07-2023, 07:27 AM   #3
Grgstudios
I’m going to double check the pressure readings today, thanks for your comment!
Wasn’t sure what the normal pressure reading was, hopefully its that as it’s an easy fix!
