07-07-2023, 01:47 AM | #331 | |
Rep 7,429
Race oil is not meant for street use because it lacks oxidation resistance to enable it to last for long periods of time. Literally some race oils are meant for a couple of track days or maybe a few months of use (and that's probably pushing it) before being flushed.
07-07-2023, 02:16 AM | #332 | |
Rep 8,970
MOTUL Gear Competition 75W140 LSD 1L 100% Synthetic Transmission Oil 105779 Other have discussed, but do you think it's not suitable for street use? |
07-07-2023, 02:46 AM | #333 |
Rep 7,429
No that should be ok for street use. It specifies manufacturer recommend OCI as well, so it isn't completely track only.
07-07-2023, 08:33 AM | #334 |
Rep 158
07-12-2023, 09:51 PM | #335 |
New BMW owner
325
Rep 843
Probably the same with mine coz I did the oil first then those 2. I guess I should drive it around again after the oil, set it back on the lifter again for the diff and tranny. That way it's nice and hot for a more complete drain. Just too lazy to bring it down, drive and reset it back on the lifter again.
kthor70348.00 |
08-20-2023, 07:01 PM | #337 |
New BMW owner
325
Rep 843
Should have open the fill plug first. Just saying.
Upgraded diff? Last edited by vrooooom; 08-20-2023 at 08:03 PM.. |
08-20-2023, 08:04 PM | #338 |
Rep 7,429
Nice!
That's really grey for 650km despite it being break in. You might have to flush a second time after 1200km or 2000km just to be safe. How'd you code out the diff? And how do you like the feel vs. stock? Yup that's true. It would allow for a laminar flow as well instead of the glugging.
08-21-2023, 12:51 AM | #339 | ||
Rep 1,335
The coding was done for me by a friend, the feeling is impressive, one of the best mods. |
chris7197334.00 |
08-21-2023, 01:39 AM | #340 | |
Rep 7,429
Keep us posted.
08-25-2023, 08:56 AM | #344 |
Rep 422
Drives: F87 M2 DCT, F15 X5
Yeah, I see that… I just curious what your hoping to accomplish. From my professional experience, 1 break in change is enough to flush any significant break-in wear metals and assembly contamination out of the system.
Does the CSR/Drexler require multiple changes? |
08-25-2023, 12:29 PM | #345 | |
Rep 1,335
08-25-2023, 12:42 PM | #346 |
Rep 422
Directionally, the cleaner the oil, the longer your bearings will live and the slower the oil will oxidize in service. In durability testing I have conducted professionally, the oil is never really "clean" after it goes in the gearbox. Even after you break in the product, and change the oil. There seems to always be some minimum level of contamination that sticks around. Fortunately, the bearings and oil change intervals are typically designed for long life in whatever the manufacturer considers normal operation conditions (temp, loads, speeds, contamination levels) with specified statistical reliability.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
08-25-2023, 02:50 PM | #347 |
Rep 8,970
Looks OK visually, assume the oil was blue when it went in?
Have you sent it away for analysis? And why the neck don't you take out the fill plug first to get a smooth drain? |
08-25-2023, 03:33 PM | #348 |
Rep 7,429
It's alot better, there's actually some color in it now. It probably needs one more flush to be perfect. I'd probably do it after 1,000km for this one.
08-25-2023, 03:36 PM | #349 | |
Rep 7,429
08-25-2023, 08:00 PM | #351 | ||
Rep 1,335
I don't plan to analyze it. Last edited by Track/S; 08-25-2023 at 08:07 PM.. |
08-25-2023, 08:15 PM | #352 |
Rep 7,429
Sounds good, let us know how the drexler does on track.
