05-23-2024, 03:20 PM | #2 |
Rep 26
I'm not sure what source I used but the service interval notes in my phone says to change it at 50k miles. I'm at 51k & literally just ordered the hose minutes ago to change preventatively
05-23-2024, 05:47 PM | #3 | |
31314
Rep 9,221
My car is garaged so I open my hood every time I pull in The reason behind this is to let the hot air out of the engine compartment It increases the life of the rubber and plastic and also heats the garage at the same time
05-23-2024, 06:01 PM | #4 | |
The Seeker
14957
Rep 3,685
///M TOWN31314.00 |
05-23-2024, 06:36 PM | #6 | |
31314
Rep 9,221
It actually helps because the turbo puts off a lot of heat and letting that heat out will help stop cooking the plastics Also, after owning a high strung supercharged car, I’ve learned that opening the hood will allow you to spot concerns before it’s an issue that you have to deal with on the side of the road
05-23-2024, 06:41 PM | #7 |
Rep 509
Drives: F87 M2 DCT, F15 X5
Mine blew on my F30 N55 at ~98k miles and 8 years old for reference.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
05-23-2024, 06:48 PM | #8 |
Rep 509
As an interesting note, when I had my 987.2 Cayman S, it would kick on the radiator fans high if I garaged it and shut the garage door. I remember hearing a noise outside and the garage was so hot because of all the heat the fans were pushing out from the engine compartment. I now leave the garage door open for a bit after I park the car if it is convenient to keep some airflow around the car.
‘18 F87 M2 DCT
///MPhatic14956.50 |
05-23-2024, 07:06 PM | #9 |
Rep 4,014
That won’t do a thing you might as well put it back.
05-23-2024, 07:30 PM | #10 | |
31314
Rep 9,221
Gas mileage for an example,I’d say probably 2 miles per gallon or more same as running a front license plate
05-23-2024, 07:31 PM | #11 | |
31314
Rep 9,221
Especially during the summertime Just not enough for my neighbors dog to get underneath… That ratbastard shows up without notice
05-23-2024, 08:42 PM | #13 | |
Rep 3,644
If it's a garaged car probably 9-10yrs, and 100-120k mi. My garaged 328d (same coolant tank/line as N55) is at 105k and 8yrs without signs of becoming dry/brittle.
///M TOWN31314.00 |
05-23-2024, 09:37 PM | #14 |
31314
Rep 9,221
At least your proactive by keeping an eye on it just incase…
05-27-2024, 05:41 PM | #15 |
Rep 474
Just replaced the overflow hose on my car proactively at 52K miles. It's fairly cheap (~$60 iirc), and very easy to do. I'm sure it would have gone another 20-30K miles, but I'd rather replace it well before any risk then have it blow when I'm out somewhere.
Besides, the car is also 7 years old, and it was a good opportunity to do a partial radiator coolant replacement at the same time. Not really a flush, but replacing nearly 2/3 of the fluid (4.1L out of 6.7L total) is a big improvement. I also replaced the 'mickey mouse' fitting and thermostat hose at the same time. That's a lot more fiddly, and I definitely could have let that go a few more years. But as long as I was doing coolant bits I figured I might as well do another item that's known to fail. Used the ECS metal fitting and silicone hose kit. Very nice piece. |
jefe2000851.50 |
