11-20-2018, 10:54 AM | #1 |
Hye
22
Rep 140
winter set with bmw recommendation
I am trying to get a winter set going for my m2. Any recommendations in GTA for reasonably prices set?
BMW Toronto recommends 235/40/18 front 255/35/18 rear
11-20-2018, 03:21 PM | #2 |
Rep 1,092
Those sizes would work well. Most people run square setup 235/40 or 245/40 on 18s.
I picked up these - https://www.1010tires.com/Wheels/720...d/Matte+Black/ Cheap, super light, and the right offset (18x9 ET30). |
11-20-2018, 03:53 PM | #3 |
Rep 7
Hi! my winter setup arrived today. I fitted a square setup, wheels 18 x 8, et 30, tyres 235/40 r18. Europe, Romania here, MAK Wheels with pirelli sottozero 3. All good so far.
11-23-2018, 07:52 AM | #4 | |
Rep 3
Could you post some pictures? Thinking of fitting 18x8 ET30 on mine but unsure if they'll need spacers.... (as they've recommended here: https://f87.bimmerpost.com/forums/sh....php?t=1558302 ) Thanks! |
11-23-2018, 05:10 PM | #5 |
Rep 1,092
I posted my setup that's available in Canada here- https://f87.bimmerpost.com/forums/sh...1&postcount=51
As far as 18x8 ET30 yes, they will fit but I would run 20mm spacers to make it look better. Basically 20mm spacer would make it look similar to the link above (those are 18x9 ET30 with 10mm spacer) |
11-29-2018, 02:33 PM | #6 |
3530
Rep 6,752
We recommend going with 18x9" ET31 wheels paired with 245/40-18 tires all around. Those will be a direct fit, bring more balance to the car and allow you to effectively rotate your tires when needed. We wrote an in-depth article about winter wheels and tires for the M2 if you are interested. Check it out here
