BMW M2 Forum > BMW M2 Discussions > Headlights does not align 100% correct (left and right)
      02-13-2017, 11:22 PM   #1
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
Anyone else has the same issue that the front lights don't align 100% correct on his M2? There is a difference in the gap between the left and right headlight on my MY17 M2.... Does anyone else has this? Or should my BMW dealer be able to resolve this minor issue?
      02-13-2017, 11:35 PM   #2
Tag
this is the way
Tag's Avatar
18151
Drives: N-1 starfighter
Did you lower your car?
      02-13-2017, 11:37 PM   #3
Franzino
Franzino's Avatar
Belgium
860
No; 100% OEM....why would lowering the car chance the position of the gap between the headlights? Make no sense at all
      02-13-2017, 11:45 PM   #4
Tag
this is the way
Tag's Avatar
18151
Headlight level sensor is on the lower control arm.
      02-14-2017, 02:07 AM   #5
Franzino
Franzino's Avatar
Belgium
860
Does this alter the gap between the headlights and the front bumper...?
      02-14-2017, 06:57 AM   #6
Prodigy.
Prodigy.'s Avatar
698
Drives: ///M2
Am i correct in saying you have PPF installed on your car? Did they remove the headlights by any chance when applying it?
      02-14-2017, 09:27 AM   #7
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
I think he thought you were saying headlight PROJECTION was off.
      02-14-2017, 10:26 AM   #8
David1
David1's Avatar
Drives: 09 E92 09 X5
Standard BMW 2 series lack of panel/light alignment. I spent a lot of time aligning my headlights, bumper, and hood. Front end fitment on the 2 series cars is all over the map from great fit to fits like ass. Just look at them on the lot, they are different from car to car. It's ridiculous. The old 5 series cars were even worse.
      02-14-2017, 02:49 PM   #9
MMMBRAP
Drives: A Car
Originally Posted by David1 View Post
Standard BMW 2 series lack of panel/light alignment. I spent a lot of time aligning my headlights, bumper, and hood. Front end fitment on the 2 series cars is all over the map from great fit to fits like ass. Just look at them on the lot, there are different from car to car. It's ridiculous. The old 5 series cars were even worse.
That's worrisome. Thanks for the heads up!
      02-14-2017, 11:17 PM   #10
Franzino
Franzino's Avatar
Belgium
860
Good thinking, bit they did not remove the bumper or headlights when fitting my X-pell...
      02-14-2017, 11:18 PM   #11
Franzino
Franzino's Avatar
Belgium
860
Was thinking the same thing...
      02-15-2017, 12:09 AM   #12
atxsk8r
atxsk8r's Avatar
Drives: 2020M2C
Did you install black kidney grilles? If yes, i had a similar issue when i screwed back the front bumper, it wasn't aligned correctly and was a simple fix to adjust the top bolts. If not, i would still try to adjust the bumper first before going to the dealer, see if you can align it correctly.
      02-15-2017, 05:27 AM   #13
David1
David1's Avatar
That has nothing to do with the headlights.
      02-15-2017, 07:40 AM   #14
DivideBYZero
DivideBYZero's Avatar
484
Drives: F87 M2<E92 M3<E46 M3
Well, it does in this case. The OP is worried about the panel gaps, and not refitting the bumper properly after fitting the grilles will impact the gaps around the headlights.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      02-15-2017, 11:25 AM   #15
David1
David1's Avatar
Fitting the grills has no impact on the headlight gaps and you do not remove the bumper to install the grills, you just lift up the top section. I have done many of them. The bumper does not move left or right with the top screws loose or out. I have had to align many 2 series cars front end fitment right off the lot no matter what grill is on it. I just looked at an M240 where the drivers side light is actually touching the bumpers lower section beneath the headlight and on another the light is so far up I can almost get my pinky finger underneath it. The light housings do have a good amount of adjustability to get them optically lined up. I'm not even going to mention how poorly the fenders line up and no amount of shimming can fix.
      02-15-2017, 11:30 AM   #16
David1
David1's Avatar
I will post pics on how perfect I have mine adjusted to.
      02-15-2017, 12:00 PM   #17
DivideBYZero
484
OK, cool.
      02-15-2017, 06:55 PM   #18
David1
David1's Avatar
Here are how I have mine aligned. The first picture is the upper adjustment. The lower bolts require the bumper cover to be removed. There is enough movement in the top bracket to move the light around on a rotating axis to not worry about the lower bolts. Just trial and error till you find your cars sweet spot.
      08-19-2023, 02:35 AM   #19
Mollyran
Drives: 220i
Thanks David1, that was very helpful!
