01-31-2023, 07:03 AM | #1 |
Rep 221
N55B30T0 Block Difference
As the title states, is there any real difference from the M2’s block compared to the M235i, for example?
It’s settled that the block is open deck (which matters far, far less than people make it seem). I’m wondering if there are any real changes. I understand part numbers are a little inconsistent on many sites. Thanks! |
01-31-2023, 08:06 AM | #2 | |
Rep 4,146
Mods: Yes.
01-31-2023, 04:18 PM | #4 |
Rep 5,372
The block itself is the same, but I recall that the M2 block does have different piston oil squinters though. The M235/M2 share the same forged crank, S55 rods, and S55 bearings. The M2 has different pistons and also has the MUCH better S55 oil pump/sump system too.
VicF87OG72.50 shaneguags1192.50 |
01-31-2023, 08:58 PM | #5 | |
Rep 221
There isn’t a track day that goes by that I’m not thankful for the sump we have |
02-02-2023, 07:23 AM | #7 |
Rep 221
02-02-2023, 07:25 AM | #8 |
Rep 1,644
[QUOTE=3LiterBeater;29799762]From a technical standpoint, that guide is lacking in many ways. Also, BMW’s documents have shown false information historically, I would take it with a grain of salt.
Their technical training docs are historically very accurate. Unlike their marketing materials. |
VicF87OG72.50 |
02-02-2023, 08:16 AM | #9 | |
Rep 221
[QUOTE=PackPride85;29799767]
That said, the training document doesn’t go into the “nitty gritty” details as to exact part differences. I think it’d have to be much larger to capture all of that |
02-07-2023, 06:16 PM | #10 |
Rep 4,146
Because of this thread https://f87.bimmerpost.com/forums/sh....php?t=1981744 and the current one, thinking about the differences between the M235/m2 - I decided to "dethrottle" (per the words used in the BMW technical document found in the link above) my car. I went ahead and bought the AWE 3" midpipe for the M235 to install with my MPE, though I may change for a more custom muffle later.
Lets see if I can get a few more ponies, especially at the top end. I think the N55's weaker head flow means every bit helps.
Mods: Yes.
///M TOWN16569.50 hihowareyougood125.50 |
02-10-2023, 08:54 AM | #11 | |
Rep 221
Then again, I shouldn’t be quoted there lol. |
02-10-2023, 09:28 AM | #12 | |
16570
Rep 8,427
02-10-2023, 10:50 AM | #13 | |||
Rep 4,146
Just to quote myself from another thread:
Inspired by my post here https://f87.bimmerpost.com/forums/sh...7&postcount=18 on the differences why the F87 makes more power than other tuned N55s, BMW claims that along with the intake airbox being dethrottled (which we have tested this to be true) they have done the same to the exhaust. https://www.bimmerpost.com/goodiesfo...l-training.pdf Quote:
The 2JZ Supra has basically the same stock exhaust flow through the head (155CFM) but have seen 66WHP by moving up half an inch https://www.motortrend.com/how-to/mo...ust-test-tech/ Interestingly enough, they claimed that the 3.5" exhaust was even a benefit over the 3" in the 300whp range: Quote:
Basically, the more boost we run, the greater the restriction it becomes. The graphs showing a handful of HP at peak on these aftermarket systems is likely because on the stock tune, the cars are only running 7-10psi (Stock M235i) that tapers to redline. It should be noted there is a (claimed) significant increase at the low end. Changing a muffler isn't an exhaust system, and unfortunately, there isn't really any R&D in most aftermarket parts - so who really knows what those $1,000 mufflers do (nothing) or what's the true optimal size for FBO 16-18psi, I would bet it's larger than stock. With that being said, I picked up a AWE 3" midpipe to pair to my MPE. I wanted larger, but there is nothing commercially available I'm aware of, and this will bolt up with minimal to no modifications. I might to a better muffler, we'll see.
Mods: Yes.
3LiterBeater130.00 |
02-10-2023, 11:00 AM | #14 |
Rep 4,146
The cool thing about that turbo catback test was a bigger exhaust diameter net more power even on a stock sized downpipe - increasing the size of the downpipe even lead to bigger gains (I think almost 100whp)
guys going with Big turbos should really consider upping the exhaust diameter - unfortunately, it will likely have to be a custom job.
Mods: Yes.
02-10-2023, 03:54 PM | #15 |
Rep 647
02-10-2023, 05:09 PM | #18 |
Rep 4,146
Dyno time used to be CHEAP for me, and plentiful - since the pandemic, it's hard finding performance shops...
Mods: Yes.
02-10-2023, 05:58 PM | #19 |
Rep 221
Good stuff! Makes me want to explore a larger single exit exhausts but can’t say I’ll ever exceed stock boost targets.
Either way, interesting information. |
