06-16-2022, 02:41 PM | #89 |
a coffee drinker
96
Rep 162
Simple and elegant.
F87source has penned quite some number of posts regarding GFB DV+ considerations. These explanations will be better than mine. One example. Why? Half the cost for a small amount of bother. Basically, it is an upgrade over stock offering an improvement in performance / responsiveness as well as giving me peace of mind in the long-term. Nezil Posted thoughts that resonated with me too. Then there is this stealth challenge when living in California |
06-16-2022, 04:07 PM | #90 | |
Rep 7,429
Among that the gfb is proven to be bullet proof without fitment issues. I keep seeing turbo smart owners say their wiring harness is fraying, their o-rings are leaking, and their valves are touching the coolant hose.
06-16-2022, 07:30 PM | #91 | ||
16567
Rep 8,425
It rests against it ever so slightly
06-16-2022, 10:40 PM | #92 |
Rep 7,429
The loom can fray, not just touch.
06-17-2022, 12:08 AM | #93 | |
16567
Rep 8,425
Clearly TS fixed the oversight
06-17-2022, 12:12 AM | #94 |
Rep 7,429
Maybe they did, but the heat shrink wrap was the same as before from what I can tell.
06-17-2022, 12:15 AM | #95 | |
16567
Rep 8,425
But in my opinion the TS wiring loom is a very stout by design
06-17-2022, 02:08 AM | #96 | |
Rep 7,429
Turbo smart probably does the same thing in manipulating the plunger with a spring to keep it closed with some boost in the charged air tract, so imo I'd rather just retain the stock solenoid and improve on the piston via the gfb package.
///M TOWN16566.50 |
06-17-2022, 02:20 AM | #97 | ||
16567
Rep 8,425
So far the TurboSmart DV has exceeded my expectations The Plumb Back version is extremely quiet as expected
07-01-2023, 02:40 PM | #98 |
The Seeker
13863
Rep 3,325
I usually do all my mod work, or sometimes have a friend help, but I decided to out-source this one to a local German-whisperer. The job took 6 hours front to back with several breaks and a short trip to the parts store for a broken sway bar fixing bolt, so it can be done in 5.5 for sure.
Some notes from the job. 1. He dropped the sway bar a bit for easier access. 2. He removed the water pump to gain better access to the DV. 3. He broke the old DV in order to facilitate getting it out easier/faster. 4. The boost pipe-to-intercooler joint isn't a 100% flawless fit, but it works. 5. The PCV pipe/hose tabs broke when he pulled it off but he said it doesn't matter because the hose is bespoke for that area (it doesn't wiggle), it snicks right back on, and it's made for vacuum, not pressure. 6. He did use a ball-head allen key that he cut down to help with the top DV bolt, but he did it from the bottom, not the top. He used an Airlift to refill the coolant, and it took just a few minutes. 1.25 gallons. MST Inlet/Turbosmart DV: $477.95 Boost pipe: $137 Coolant: $47.60 Install: $400 (job was quoted low at $260, but I gave him $400) Total: $1,062.55 First driving impressions; not worth the money/effort. I'll definitely have to drive the car more before I give my final analysis, but for the cost I can't see this job being worth it unless you're having an issue with your stock DV or you have an extreme need for every last ounce of turbo noise and HP. I'll update this in a few weeks with my full impressions. Many thanks to @///M TOWN, F87source, MONSTAR , Wisco M3 and everyone else that added notes to this job. Last edited by ///MPhatic; 07-01-2023 at 06:07 PM.. |
07-01-2023, 04:59 PM | #99 | |
Rep 7,429
07-01-2023, 09:01 PM | #101 |
Rep 4,146
07-01-2023, 09:53 PM | #102 |
Rep 7,429
Yup, I noticed a very big difference with my GFB dv+
07-01-2023, 11:28 PM | #103 |
Rep 201
Same. I was mostly looking forward to the inlet pipe upgrade and the dv just cause that’s the time to do it, but it was dv that has been dv upgrade that has been so noticeable. The GFB dv+ has that (optional to install) spring that holds boost in the charge pipe, they claim if you don’t use this additional spring it will feel like the stock dv. I’m assuming the Turbosmart doesn’t have this same function, so it probably would feel pretty much as stock. The MST inlet upgrade is good too, but tbh I probably hear it more than feel it. The sound is a plus though.
I don’t get enough open road to really rev my engine out at the top, and that’s where users report they feel the difference. |
07-02-2023, 10:00 AM | #104 | |
The Seeker
13863
Rep 3,325
And now that I've taken a good long drive on my favorite roads this morning I can say without a doubt the juice on these mods aren't worth the squeeze for me. Under certain conditions the car feels like it has more power, and the boost builds quicker/there is less turbo lag, but it's not all the time at every rpm, it's just under specific conditions or long WOT times (rare for me). I imagine the numbers would tell the true story, but I'm not interested in numbers, I'm more concerned with feel, and the difference I feel can be literally down to the placebo effect. Then again, I've never had my butt-dyno properly calibrated (I noticed no difference at all with my Fabspeed sport cat either). Are these mods worth something? I imagine so, just not the price/hassle of install. |
designatedposter175.00 |
07-02-2023, 07:20 PM | #105 | |
Rep 4,146
Are you running a tune or Intercooler? |
07-02-2023, 08:17 PM | #107 |
Rep 4,146
Last question(s)
What intake (if any) and have you tried resetting adaptations?
Mods: Yes.
07-03-2023, 06:06 AM | #109 | |
Rep 4,146
It does - there is more than one adaptation to reset. Fuel trims, vanos, maf, idle, etc. I personally did lambda, maf, idle (and then later on fuel trims) when I installed my intake and inlet/DV. Smooth idle, and now great fuel trims (which were previously pretty wonky) - power increase was actually noticeable as well.
Mods: Yes.
07-03-2023, 08:57 AM | #110 | |
The Seeker
13863
Rep 3,325
You're way over my head bro. Is this an easy thing to do? |
