06-27-2020, 07:41 PM | #23 |
Rep 632
06-28-2020, 12:56 AM | #24 | |
Rep 88
Is this for a track setup or just street? If track-oriented please call Barry at 3DM motorsports, he is the suspension guru and knows about Ohlins inside out. Stock Ohlins street manners were very good, but I wanted a more track-focused setup. I had my shocks custom valved and running 12kg/22kg springs currently; body roll mid-corner is significantly better now and still feels very controlled. Just give him a call, tell him Eric sent you and he will take care of you.
06-28-2020, 03:22 AM | #25 | |
Rep 488
Have you run your Ohlins on any other tire than the PS4S? If so, what were they like compared to OEM suspension then? Thanks. |
06-28-2020, 11:47 AM | #26 | |
Rep 1,263
Both had the TC Kline D/A Koni's and camber plates. I had to replace the spherical bushings in the camber plates once on the E36M3. I also pulled the E36M3 Koni's at 70K and I had them revalved even though they were still all working fine. (changed Spg rates) I Installed a set of JRZ's RS Pro's on my Miata RF Club drove it thru its first winter and both my fronts were leaking. Total cost to pull ship, rebuild and reinstall was $2K. I installed a set of custom AST 5100's on my EVO and they never made it thru the 1st winter. I pulled them again after just another 8K miles Blown a 2nd time! Threw them in the trash. The Motons I had didn't last more than 7K before a rebuild. I sold them right away. The Ohlins R&T's i had on my EVO after the AST's never were pulled with 50+ track days, time trials and over 30 autocrosses and 6 winters on them. Buy what you like but i've been messing around with suspensions for 30+ years now. IMHE, the Koni's and Ohlins both are solid, long lasting options for our cars.
06-29-2020, 06:20 AM | #27 | |
Rep 632
All the parts except the Koni shocks rusted quickly. The springs kept binding and then learned they realized there was an error in the size with initial batch but requested I pay for shipping the replacement since I was located in Canada. A lot of other brands have QC issues as well. Just stating my experience with TC Klines. |
06-29-2020, 08:09 AM | #28 | |
Rep 1,263
The Springs on my M2 are treated with a White finish. No way they can rust.
06-30-2020, 10:59 AM | #29 |
Rep 199
Yes the original Michelin PSS....that set up was a bit stiffer than stock, but awesome in regard to road manners (no more bounce)....I have the details on a different thread out there in regard to the spring rates I used but I believe it was 80 N/nm front and 160 N/nm rear
widetyres279.00 |
06-30-2020, 07:45 PM | #30 |
3847
Rep 54,376
Drives: F80 M3
06-30-2020, 08:31 PM | #31 | |
3847
Rep 54,376
Drives: F80 M3
PLF693767.50 |
07-01-2020, 07:45 AM | #32 | |
Rep 1,263
I'll also add that IMHO the Ohlins are a slightly better damper than the Koni's. Their DFV Tech is the difference between the two struts...That's why they can use higher spg rates than Koni. I was really impressed with how mine were on my EVO X with 900/1000 springs. They managed small & medium road bumps really, really well. https://motoiq.com/how-does-the-ohlins-dfv-valve-work/ On the plus side with the Koni's they have both Compression and rebound adj. Also the softer spring rates allow me to eat up anyone I run against in the wet. If your a serious track whore, and/or a Solo 2 hotshot chasing 0.10's of second by all means go buy one of the sexy shocks. Just understand the true cost of ownership when you pull out your credit card. I really love my JRZ RS PRO's on my ND Miata with 650/350 lb spgs. That's when they are working :-)
Stylin.M2270.00 |
07-01-2020, 09:40 PM | #33 | |
3847
Rep 54,376
Drives: F80 M3
The softer rates and Koni's may feel a bit soft and not as responsive in the dry, but you are totally right in the wet. You can run circles around guys on high spring rates with monotubes! The high-end dampers are great when they are working. Keeping them working requires regular servicing. If you don't do your own work, it can get very expensive quickly. Last edited by HP Autosport; 07-01-2020 at 09:56 PM.. |
