03-29-2019, 07:01 PM | #1 |
1287
Rep 1,675
Stone chips in front radiator
I noticed the front radiator fins were bent from stone chips hitting them , behind the front grill
Anything need to be done? Is this rad used to cool engine or for air condition etc? Does this cause problem for performance? |
03-29-2019, 07:29 PM | #2 | |
16523
Rep 8,421
Stay further back from traffic to reduce it.
03-30-2019, 06:49 AM | #4 |
16523
Rep 8,421
Yes but done wrong, you can tear them unnecessarily, causing a coolant leak.
03-30-2019, 01:18 PM | #5 |
Rep 2,956
Generally for a radiator as long as it's not leaking I would leave the fins alone. I will say as a former STI owner that's driven through a hail storm where hail went through the hood scoop and pelted the intercooler, that a quality set of tweezers and some patience can make any tube and fin intercooler look new again.
F87source7251.50 |
03-30-2019, 01:50 PM | #6 |
Member
458
Rep 1,517
My radiator right behind the kidney grills is also damaged, I'm assuming from the 1500 mile drive down south on i95. I'm not sure if it's still the case but I remember the air compressor radiator would actually sit in front of the engine radiator.
Either way, I have no plan on fixing it, I can't imagine is has an notable effect
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
03-30-2019, 06:04 PM | #7 |
Rep 3,402
In Arizona we see a lot of this from the crap that tends to get on the roads after monsoon rains. My car has 37,000 miles and 20 or so track days and my coolers are very impacted by this. Does it effect performance? I'm sure it does but I wouldn't straighten them unless I knew what I was doing. Because of our hot climate and my track habit I will probably be doing the full CSF cooing package, hopefully it will be more resistant to this issue also.
03-30-2019, 06:07 PM | #8 | |
Rep 7,429
Oh yeah, my STI's intercooler looked like garbage just after ~5,000km of ownership. But yeah OP there really isn't much you can do tbh, it does happen. If I were you I probably would just leave it as is (if it is not leaking), and maybe address it by adjusting the fins with a screw driver as the issue gets worse.
03-30-2019, 07:52 PM | #10 |
BMW Fanaddict
65
Rep 76
If the fins aren't smashed down flat, leave them alone. Whatever you do, DON'T use a screwdriver or other sharp metal tool or object to try to straighten them out. They make a special tool for this - here's an inexpensive one on Amazon:
https://www.amazon.com/Allstar-ALL10.../dp/B006K8GKBO |
03-30-2019, 08:28 PM | #11 | |
Rep 7,429
04-09-2019, 12:33 AM | #12 |
Rep 477
Drives: M2CS
