M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > M2 Wheel Pictures
      11-30-2020, 09:32 AM   #705
VIERsr
Switzerland
2623
Originally Posted by Karmic Man View Post
Titan7 T-S5
Wheels: F: 9.5 ET27, R: 10.5 ET44, 19
Tyres: F: 265/30, R: 285/30
Stunning.
What tires?
Karmic Man1996.00
      11-30-2020, 04:46 PM   #706
veenut28
veenut28's Avatar
658
Drives: 2020 M2, 6MT
2020 BMW M2 Competi ...  [10.00]
  [0.00]
Titan7 T-S5
That looks great. I'm between these and the 763m wheels but leaning towards the TS5. Especially since I'd rather get the PS4 instead of the Cup2 so the standard wheel/tire set offered by BMW doesn't work.
Karmic Man1996.00
      11-30-2020, 06:59 PM   #707
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Titan7 T-S5
Finally someone that bought the correct size tires.
Karmic Man1996.00
      11-30-2020, 07:07 PM   #708
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Originally Posted by _RS4_ View Post
Stunning.
What tires?
It's a Bridgestone Potenza of some sort. I'm betting it's an S04 Pole Position.
EDIT: Weird that I'm not showing a 265/30/19 available in the S04 PP though.
      11-30-2020, 07:19 PM   #709
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
Stunning.
What tires?
Potenza S007A...very playful tyres, stiff sidewalls, can handle large slip angles and has grip straight away...highly recommended for any sort of spirited driving, for track days it won't last long.
VIERsr2623.00
      11-30-2020, 07:24 PM   #710
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Potenza S007A....
Ah, mystery solved, thank you sir!
That tire only comes in 265/35/19, in the USA. Where are you again? I noticed you wrote Tyres...
      11-30-2020, 07:30 PM   #711
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
Get the T-S5 since while weight is similar to the 763M or might even be teeny tiny bit lighter, they are wider at 9.5/10.5 vs 9/10 of the 763M. That means you can shove wider tyres like 265/295 30 19 PS4S that will allow you to out-brake and out-corner one on 763M running on a smaller set or on the same size tyres.
veenut28658.00
      11-30-2020, 07:32 PM   #712
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
No worries...I am currently in Australia
VisualEcho6636.50
      11-30-2020, 07:32 PM   #713
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Just found that those sizes are rare in the S007. But New Zealand has them. Damn.
      11-30-2020, 07:37 PM   #714
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
In the states you can get 295/30 19...
      11-30-2020, 07:52 PM   #715
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
True, but it doesn't match the front. Should be 265/30 & 285/30, or 275/30 & 295/30. And even if the 275/30 was available, it would really be too big. And besides, to get the correct fitment, now you're needing 19 x 10 & 19 x 11. This is why everyone, wanting the best tire out there, chooses the 255/35 & 275/35 PS4S. But not me, it'll be 265/30 & 285/30 Firehawk Indy all the way.
      11-30-2020, 08:57 PM   #716
lax01
Drives: 2017 M2
No problems here with 275/295 PS4S on lowered car with MPS - though I did add front camber plates
      11-30-2020, 11:43 PM   #717
VIERsr
Switzerland
2623
Thank you.
Unfortunately they're not available in Europe in those sizes
      12-01-2020, 06:45 AM   #718
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
Thank you.
You can try the Pirelli Corsa Asimmetrico 2, they have those sizes
CA2 is the OEM tyres on the Alfa Giulia Quadrifoglio
      12-01-2020, 07:21 AM   #719
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
I see your point. Though for the S007A, tread width is 10" on the 295/30 (Tire rack) so for a 10.5" rim it is perfect and on a stock size 10" rim it will also be fine.
I used to run a front 265/30 on a 9 inch rim and that steered fine. The grip is really worth it. If you are on stock rims I'll say the S007A in 265/295 30 19 should be a good setup for some spirited backroad indulgent.
The issue with fitting bigger tyres on the F87 M2 is the limited footprint for wider wheels. For ease of installation a 9.5/10.5 is plain hassle free. I would love to run a 10" front and a 11" rear in 19 (due to the M BBK) but unlike an M3/M4, that setup requires precise offset front and rear, substantial fender modifications together with aggressive cambering and the maximum rear tyres one can fit without rubbing is still only 305. That's lots of pain and not much gain, not worth it for a daily in my book.
juicy81.50
      12-01-2020, 10:06 AM   #720
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
It's not so much about the rear, it's about the relationship between the front and rear, and what you're doing with a 265/295 is adding quite a bit of understeer, and also changing the balance of the car. Being a track rat I figured you'd know this by heart.
      12-01-2020, 10:12 AM   #721
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
EDIT: I remember you now. Fit looks fantastic. Stock tires. BUT, heavy camber in the front, right?
      12-01-2020, 07:19 PM   #722
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
I guess you mean tread width ratio front and rear...not the section width. Though when driving hard, weight transfer induces dynamic variation on the axle load left and right, front and rear so tyre contact patch ratios (L&R, F&R) change all the time anyway. Tyre compounds will also make a difference. BMW's 20mm staggered was tuned for the Michelin PSS Star spec. My coming set of tyres is AD08R on 265/295 and so I will report back if there is any material difference on understeering with the 30mm staggered on the Yoko.
JTO245276.00
      12-01-2020, 11:02 PM   #723
Connors5453
Connors5453's Avatar
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Silver painted 763m wheels
Pics attached!
ebisu81079.50
Rundskop148.00
      12-01-2020, 11:58 PM   #724
VIERsr
Switzerland
2623
That's a great tire, but 265/30 are the OEM front tires on the Ferrari LaFerrari and the 285/30 are the OEM rear tires on the Giulia Quadrifoglio, not sure about the mix.
      12-02-2020, 08:19 AM   #725
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Absolutely. TW relationship is all that really matters, given the same compound front and rear.
      12-02-2020, 08:21 AM   #726
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
It's what Dinan uses as well. And IMO, they have the perfect set-up.
