11-22-2020, 08:36 PM | #1 |
Rep 100
Drives: '21 A90 Supra 3.0, '11 E92 M3C
Installation of Turner Poly Rear Shifter Bushing for 6MT?
Hey everybody,
Wondering if anybody has installed the Turner Poly rear shifter bushing for their 6MT M2 on jack stands / basic hand tools? I don't have access to a lift, and I actually am totally fine with the throws of the stock shifter so not looking for an SSK combo that a shop would install at the moment. Just looking to increase some shifter feel and reduce some of the "vagueness". The install guide on Turner's page says: "Installation is easy, once you remove the heat shield from under your car the old bushing is held in place with 2 star socket fasteners. Simply lube up the tail of the arm with any silicone based grease to position the bushing onto the shifting arm." But, as with all things, an "easy" install could definitely be a bit harder on jack stands, so just wanted to see if somebody had done a DIY! Thanks in advance. Product link: https://www.turnermotorsport.com/p-5...ifter-bushing/ |
11-23-2020, 11:52 AM | #2 | |
381
Rep 731
At a Point above 7,000 RPM.
11-23-2020, 09:53 PM | #4 | |
Rep 7,342
11-23-2020, 10:04 PM | #5 |
381
Rep 731
Partially at the Rubber Flange which was 3 bolts. Probably could have gotten away with not doing this but my hands are larger and it made it easier. Just make sure you mark flange with a marker to go back as before if you drop it.
11-23-2020, 10:32 PM | #6 |
Rep 7,342
Thanks for the advice!
11-24-2020, 09:07 AM | #7 | |
Rep 100
Also what is this "large panel under the gearbox" you speak of? |
11-24-2020, 06:59 PM | #8 | |
Da Baus
282
Rep 259
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
11-24-2020, 10:01 PM | #9 | |
It's not how fast you go, it's how you go fast.
26
Rep 23
I used a 1/4" drive ratchet and was able to reach the bolts with an extension and a universal joint attachment. No need to remove the drive shaft (heavens forbid). The tricky part is probably getting your hands in there to start the bolts during reassembly. A nice headlamp helps you see everything. I did this on my driveway with the front wheels on ramps. As long as you're not built like Santa, you probably have enough room. |
hson10140.00 |
11-24-2020, 10:13 PM | #10 | ||||
Rep 100
2021 A90 Supra 3.0 Nitro Yellow, 2011 E92 M3 Comp Jerez Black
Instagram @hans.device |
08-12-2021, 09:16 AM | #11 |
Rep 129
Drives: 2018 BMW M2
Just installed this yesterday, wasn't hard at all. Maybe just make sure you have a E10 1/4" drive socket with a swivel. Although I think a 3/4" drive would have worked just fine. 1 bolt was a straight shot actually no swivels needed the other one is almost a straight shot although I didn't try and just used the swivel.
Only thing that took me sometime was bending the turkey tray heat shield out of the way to slide out behind the drive shaft. But it wasn't very difficult took maybe 5 minutes to get it out. Super straight forward pretty satisfying job to do!!! |
F87source7177.50 |
08-19-2021, 02:19 AM | #13 |
@lbb_kev
482
Rep 508
I noticed a reduction in clunky shifts after installing the rogue engineering trans mounts. This is after already driving with the auto solutions short shifter for a few months
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | Dorch Stage 3 HPFP | Nostrum S2 Injectors | Walbro 535 | EOS EKP | BendCalibration Flex Fuel Kit | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
chris7197273.00 |
08-20-2021, 12:40 AM | #15 |
@lbb_kev
482
Rep 508
The auto solutions improves overall shift feel yeah, but the trans mounts reduces deflection so everything is tighter in between shifts - this makes the shifts less clunky.
It's a cheap upgrade parts wise and labor wise.
08-20-2021, 02:02 AM | #16 |
New BMW owner
318
Rep 831
yeah i think i'll try this out. Thanks.
09-08-2021, 09:03 AM | #17 |
Da Baus
282
Rep 259
I did this but also rtd shifter same time so idk lol. Its cheap and your there same time
09-08-2021, 11:33 PM | #18 | |
New BMW owner
318
Rep 831
Did you do BOTH the Turner Poly Rear Shifter Bushing AND the Rogue's transmission mount? https://www.rogueengineering.com/Rog...nts_p_137.html
09-09-2021, 09:19 AM | #19 | ||
@lbb_kev
482
Rep 508
It took my shop around 1-2 hours to install. Wasn't a hard job by any means.
04-02-2023, 12:46 AM | #20 |
Rep 548
I recently installed the Turner rear bushing, posted re a specific issue in CS subforum but as it applies to all F87 thought it worth sharing here. I have had the Auto Solutions SSK (+ blue poly bushings) for 3.5yrs, BMS clutch stop (2 shims) since new, Raceseng Circuit Sphere knob (did have intermittent buzzing with oem knob after SSK), CDV delete 1yr ago then Rogue trans mounts 6mths ago.
imo the Turner bushing gave an improvement about the same as the Rogue mounts did, a little more feel/precision/tightness but no additional effort to engage gear. What did come with the Turner bushing (I'm sure because I already had the AS SSK polyurethane shift arm to transmission mounts) was a significant increase in NVH. At idle you can hear whine/chatter but with hard acceleration/deceleration there is loud gear whine. My car isn't a daily commuter and I now actually like the extra excitement it gives in mountain twisties, wouldn't recommend it if you daily commute and listen to radio/music. Before installing the Turner I would say NVH was virtually at oem level (except for the buzz I had with oem shift knob, eliminated with Raceseng knob). For anyone who already has the AS SSK and read/heard that Ron recommends against the Turner bushing, here is a reply from Ron clarifying: "I cannot comment on the current Turner poly bushing. the one that was given to me was a couple years old and I felt it held the back of the shifter arm too tightly therefore robbing control from the front setup. I recommended then to slightly enlarge the hole so that the bushing would act as a limiter rather than a controller. And theorized that it would work very well in that case except for the noise. I drove such a bushing on an e46M3 in its tight form ( it was a generic blue poly bushing) and I felt it hurt the pattern rather than help it. it felt firmer but not as precise especially when pushed hard. So it sort of validated my theory. So for both noise and control reasons I felt it was not a positive . However a tight rear bushing would likely work well if the rest of the mounts (motor mounts and gearbox mounts) were solid or close to solid. In such a case the whole drivetrain moves as one with the body and the rear bushing no longer controls the rear of the shift arm independently from its front I hope this clarifies my position" |
04-23-2023, 07:28 AM | #21 |
Rep 33
follwoing I also had it installed with an RTD and RE Trans Mounts on my e46. On my new to me m2.. im also trying to fix this stock shifter.
