View Poll Results: Have your M2C rear indicator units failed? | |||
Yes | 136 | 63.85% | |
No | 77 | 36.15% | |
Voters: 213. You may not vote on this poll |
12-05-2020, 11:18 AM | #199 |
Rep 271
So I took in my car yesterday in for it's first service (not run-in service) & asked them to check the rear indicator issue, they came back and said they need to replace both the rear light units. Will keep an eye once it done and give an update!
Instagram: m2c_sxm
12-19-2020, 08:29 PM | #201 |
Rep 166
Brought mine in for this. Was happening frequently to the left but would sometimes happen to the right. I took pics of the notification in case they pushed back. They said they tested both tails and they shorted out so they were replaced under warranty. Oh and they replaced the entire grill because the sticker was peeling.
12-20-2020, 01:05 PM | #203 | ||||
Rep 4,048
01-12-2021, 07:55 PM | #206 |
Rep 1,078
Wow so we just keep on replacing for the duration of ownership. Great.
01-12-2021, 09:59 PM | #208 |
Rep 2,067
01-13-2021, 04:00 PM | #209 |
Rep 149
My rear was doing this too and car is now out of warranty. I cleaned the connector and the socket and its been working fine for about 2 weeks now, without any issues. I'd recommend this as a first step.
01-14-2021, 07:05 PM | #210 | ||
Luxury at the redline :)
9105
Rep 7,563
I retrofitted these LCI taillights and coded out the warm bulb check(s) on mines since 03/2018 and counting and they've been working fine, since then. I have honestly never encounter a single error or issue, it's been one of best upgrade I've done is 100% contented with the results. I even had my iDrive knob replaced, which required a full i-Level software update and did not hear a peep from my franchise dealer, in relation of this coding and hardware change. BMW even list this LCI taillight retrofit as an official option now, which requires 'encoding' i.e. removal of the warm bulb checks (see below). Not to mention, the same retrofit has been done and tested with tens of hundreds others members here, without any such incident you mentioned. Had your said issue been remotely related to this change, there would be a lot more testimonials, with many others bitching about this defect. The result is undisputed and many other's personal feedback pretty much speaks for itself. Can you maybe post of up a photo of the variation of the lighting, maybe that might give me a clue of what the issue might possible be. M2 LCI tail lights retrofitted on pre-LCI M2 https://f87.bimmerpost.com/forums/sh....php?t=1397351 DIY: LCI Tailights https://www.2addicts.com/forums/show....php?t=1405431 . Last edited by Poochie; 01-16-2021 at 05:51 PM.. |
QuarterMileJoe9.00 |
01-15-2021, 06:26 AM | #211 |
Rep 1,644
Have you tried topping up the blinker fluid?😏
bngcruiser277.00 |
01-15-2021, 10:00 AM | #212 |
Rep 269
I'm bringing in my car to service Monday for left and right rear turn signal malfunctions within the past month. Do they save the errors to the DME/ECU? Since they most likely won't be present upon inspection... hoping they will replace both and let me be on my way.
01-15-2021, 10:24 AM | #213 | |
Rep 1,899
However now my other side is having the problem about a year later |
01-15-2021, 11:53 AM | #214 |
@lbb_kev
491
Rep 514
Yup. Having this issue on my driver side indicator. Even when I want to use my turn signal, my BMW won't let me!
01-19-2021, 06:53 AM | #215 |
Rep 266
Drives: '89 Land Cruiser, '18 M2
Mine just popped yesterday / have an appt next week
01-21-2021, 11:10 PM | #216 |
Rep 11
Drives: BMW M2 Competition 2018 f87
When my left indicator gets 50% dimmer, I would give it a bang then it works fine. But it will still come back. I might try this method, cleaning the socket and connector. Thanks mate!
01-22-2021, 09:42 PM | #217 |
Rep 149
For what it's worth, I drove it around in the rain and also in a car wash and the indicator is working fine still. Fingers crossed, it stays that way.
02-07-2021, 06:27 PM | #218 |
Rep 11
02-09-2021, 03:26 AM | #219 | ||||
9105
Rep 7,563
Mines has a pretty bright amber hue and has been working find for over 3 years now.. And LCI taillights are cheap, relatively, like $220 new or $100 used. Mines looks exactly like these guys below, on both sides: . |
02-10-2021, 08:08 AM | #220 |
Rep 149
Mine did this too with indicator warm disabled.
I turned it back on and cleaned the taillight connector and it's been flashing nice and bright again. It might fail at some point in the future, but been good for over a month now |
