04-04-2019, 01:15 PM | #45 | |
Rep 3,842
04-04-2019, 02:29 PM | #46 |
this is the way
18143
Rep 8,521
S55 Oil Drain Plug
Engine Type: S55 Oil drain plug to magnesium oil sump. - Drain Plug Thread: M16x1.5 - Tightening specifications: Replace oil drain plug and gasket (sealing ring). - Torque: 20Nm Engine Type: S55 Oil drain plug on aluminum oil sump. - Drain Plug Thread: M12x1.5 - Tightening specifications: Replace only the gasket (sealing ring) of oil drain plug. - Torque: 25Nm |
4
04-04-2019, 07:30 PM | #47 | |
Rep 1,017
04-05-2019, 06:36 AM | #48 |
Rep 2,736
'19 M2C HS, 6-Spd, Slick Top, MComp Wheels
'18 GT3 White, 6-Spd, Buckets, PCCBs |
04-05-2019, 08:32 AM | #49 |
Rep 2,505
After VW and other manufactures caught cheating with the emission scandal. No I will not trust a any car manufacturer at all. Part of the whole cheating scandal is competition itself to compete with other manufacturers fuel economy numbers, etc.
cptobvious2531.50 AlpsRider2865.00 |
04-05-2019, 10:41 PM | #50 | |
Rep 7,297
There is really no advantage to running a 5w-30 vs 0w-30 other than cost or maybe shear stability. At 100C the viscosity is going to be nearly identical. As always, the real truth is complicated - sometimes decisions are against the wish of the engineers, but you can't make a blanket statement. Last edited by chris719; 04-05-2019 at 10:59 PM.. |
devo755.00 |
04-06-2019, 02:40 AM | #52 | |
Rep 8,970
As the w weights are cold cranking at -40 or something. The hot rating is at 100degC. And they vary with temp in between of course on a curve. So a 0W at -40 will be thicker than a 5W at -10. If you don't have mega low temps in winter then you don't really need the full benefit of a 0W. Then at 100deg a 5w30 or a 0w30 or a 10w30 will all be nearly the same. For me there are more high perfornance Ester based full synthetic oils available at 5W-30 than 0W-30. I'm not interested in BMW LLx sponsorship / approval as i don't want a long life oil. |
04-06-2019, 11:09 AM | #53 |
Rep 3,968
All, if yow want to do it early, go for it. But reach out to Blackstone Labs and get a free oil analysis kit
https://www.blackstone-labs.com/prod...ree-test-kits/ Fill it up and send in (along with $28) and then post your results. Consider paying the extra $10 for the TBN test as well. Then we can stop this guessing game.
Protatomonster275.50 |
04-06-2019, 11:51 AM | #54 |
Rep 81
I was a forum member back in 2002-2009 (2002 M3) and numerous board members sent their oil to Blackstone. The results typically showed that oil would start breaking down at 6k miles. Of course, different engine, oil capacity and oil type (10 - 60 weight)
04-06-2019, 12:14 PM | #55 |
Rep 218
Good information here. I used to be rather exuberant about oil changes and did them around 3,000-4,000 miles on all my cars. But in recent years I don't have a lot of time to DIY or deal with dropping off and picking up cars to get serviced. I've been following the recommended intervals in the manuals for normal driving, more frequent for hard driving and cold weather, and an oil change and filter before a track day. It sounds like that's in line what you guys are saying.
Questions...
04-06-2019, 12:52 PM | #56 | |
Rep 2,736
I cannot imagine an oil extractor removing nearly as much oil as removing the plug. DIY changes are easy so why mess with an extractor. I'd rather pay retail for a proper change. I'd also change the filter every time when changing the oil; interim track day change or not...
'18 GT3 White, 6-Spd, Buckets, PCCBs Last edited by devo; 04-06-2019 at 01:00 PM.. |
04-06-2019, 02:17 PM | #57 |
Rep 8,970
Never change oil without new filter IMO.
Those oil extractor's are prett good, but they need to push a pipe down the dipstick tube to get to the sump, but as S55 has no dipstick there is no easy way to get a extraction hose to the sump. |
04-06-2019, 11:29 PM | #58 |
Rep 3,968
I'll add one comment, just to stir things up - I bet those that do the oil change early are also the ones that follow the BMW break-in recommendations
Funny how the "BMW engineers" can know so much and yet so little
devo755.00 |
04-07-2019, 01:04 PM | #59 |
Rep 81
Good point -- guess I should have done break-in service at 600 mi 😎? Actually, my SA is proponent of going past the 1,200 mi. Wonder how the engineers came up with 1,200 mi. Does anyone know if break-in oil is different than standard 0-30 weight? Any special additives etc?
04-07-2019, 01:06 PM | #60 | |
Rep 2,736
I do not think a special break in oil is used... however, if it was leave it in for the mileage the manufacturer recommends. I'm sure BMW engineers just guessed at 1,200 miles
'18 GT3 White, 6-Spd, Buckets, PCCBs Last edited by devo; 04-07-2019 at 01:31 PM.. |
04-07-2019, 01:28 PM | #61 | |
Luxury at the redline :)
9105
Rep 7,563
You believe when you take your car in for an oil change at the dealer, they replaced the sealing ring also. I never seen it invoiced but the SA claim that they do replace it : I used to have this problem at the Acura dealers because they look at me like a douche, when I supply them with my own oil drain plug crush gasket, at the time of my oil change, to ensure it was changed. I'm not really anal but just thorough because I don't like dealing with blowbacks by silly mistakes that humans make |
devo755.00 |
04-07-2019, 01:50 PM | #63 | |
this is the way
18143
Rep 8,521
04-07-2019, 03:19 PM | #64 |
Rep 8,970
I always thought it was because the EU average mileage per year has been 12,000miles / 20,000km for years and years.
So 10% of 12000 is 1200 miles, simple. I'm sure it's just a one-distance-fits-all-guess. Mine was run in after 400 or 500 brisk miles to get the rings bedded, that's it. But ended up waiting to 1000 miles to get the oil out which was more about spare time than anything else. Last edited by doughboy; 04-07-2019 at 03:29 PM.. |
04-07-2019, 04:31 PM | #65 |
Rep 142
Interim Oil Change
My car does only track mileage. I store it at the track, so don't even have to drive it there or trailer it.
Based on my previous cars I've used in similar manner, I expect to do <3000kms a year. General rule of thumb in my circles is that track usage is AT LEAST 10x harder on the car as commuting is. Given my car will only see this usage, I use the factory service intervals divided by 10; for all maintenance. When I competed in the local drifting series, my car didn't have the OEM odometer. So I just counted tanks of fuel. Oil change every 5 tanks of fuel. This was similar to what others adopted. Some did less often, generally those who ran stock motors with bolt ons; bought another core engine when the current popped. Others changed more frequently, usually higher budget motors / builds. My oil came out used, but not filthy. A service every 5 tanks of fuel, is thereabouts the same as OEM service schedule / 10. My M2C is a 2 - 3 year car. I'm not sure what I'll get next, 2 - 3 years to decide! When I go to sell / trade it, it's critical to me that it appear as a low mileage, original, near mint example; to maximise residual. Although I have a warranty, I don't plan on running 1000 lap old oil, warranty or not; that's just careless. If my M2C was a forever / long term hold car, I would adopt the same strategy purely for the emotional satisfaction of keeping something pristine. The M2C isn't that car, but a CSL could be... If my M2C was a daily, 2-3 year car, 20,000kms a year, low/no track usage, I'd just stick to the maintenance schedule as my residual will be governed, so pointless to me to increase cost of ownership. This is exactly how I look at my Subaru Outback (my daily). |
04-07-2019, 08:21 PM | #66 | |
Rep 81
devo755.00 |
