11-26-2020, 06:38 PM | #1 |
Rep 62
I'm trying to install a set of m performance coilovers I just purchased and I can't seem to find the right socket skinny enough to fit the rear to take the 12 point nut off. Is there a specific tool I need to buy from BMW or any other place? Help is greatly appreciated. Thank you.
11-26-2020, 08:17 PM | #2 |
Rep 485
The ghetto way I did it was a quick blast with an impact. I wrapped a rope around the shock shaft a few dozen times and a buddy held it. Definitely spun the shaft a little but I wasn't concerned.
11-26-2020, 08:20 PM | #3 |
Rep 62
I was thinking that too but I can't even get to the 12 point nut lol. What socket did you use ? What brand ?
11-26-2020, 08:29 PM | #4 | |
Rep 485
11-26-2020, 08:32 PM | #5 | ||
Rep 62
11-26-2020, 11:17 PM | #6 |
Rep 1,092
On the front it was 12 point 18mm, this looks the same. So I held the 18 with vise grips and had a 1/4inch extension with 10mm going through it holding the shaft. Makes sense?
11-26-2020, 11:53 PM | #7 |
Recovering RS4 owner
297
Rep 266
this. use a 1/4" 10mm and extension, with the 10mm socket inside the 18mm and the extension going thru the top
11-27-2020, 05:35 AM | #9 |
Rep 62
11-27-2020, 05:36 AM | #10 | |
Rep 62
11-28-2020, 05:03 PM | #11 |
381
Rep 731
Top Hat Sockets
Turner sells a 5 piece set of sockets just for this. Will be ordering one when I do my suspension.
At a Point above 7,000 RPM.
11-28-2020, 08:55 PM | #12 | |
Rep 140
They are thin enough to go through and it also has the 22mm pass through that you'll need to torque the new nut that will come with the new coilovers. I bought a flare nut crowfoot to attach to this so i could also use with the torque wrench. edit. just realized it's sold out on amazon. maybe find something similar. |
11-28-2020, 09:24 PM | #13 |
Rep 396
If you already have the car apart and need a McGyver solution because you can’t get the right tool, buy a cheap set of plumbers tap wrenches / tube spanners.
Find the one that almost fits and tap it down over the nut. They are very soft and will deform to fit the nut. Plus they aren’t on that tight anyway. Photo shows one I used for this purpose. 2.jpg[/img] |
11-30-2020, 01:26 AM | #14 |
Monkey
119
Rep 241
