11-25-2020, 06:49 AM | #1 |
Rep 65
2020 M2C wheel choices
I am looking to upgrade the wheels on my M2C. Want to maintain ride quality but improve handling. Looking at 19 x 9.5" front and 19 x 10.5" rear with probable Michelin Pilot Sport 4s tires: 265/30-19 and 295/30-19. Running OEM suspension.
Current front runners are the Apex EC-7 and the Titan7 T-S5 wheels. Realize the Apex are flow formed (currently forged are not available in appropriate size) and the Titan are forged but also a significant price delta of $1500. Looking for feedback on both wheels. Thanks in advance for the help. No rush as my current wheels/tires have only 3k miles of use. |
11-25-2020, 07:52 AM | #2 | |
Rep 1,759
On a side note, from my observation on the current front and rear fender/tyre clearance, I believe Titan's offset (ET27 front and ET44 rear) will allow me to run 275 front and 305 rear (Falken RT660 when available) on stock suspension without rubbing. Last edited by Karmic Man; 11-25-2020 at 08:09 AM.. |
11-25-2020, 11:03 AM | #3 |
Rep 15
I personally like ec-7 in race silver. My M2C is H. silver and not sure if race silver or anthracite is better for that color car. Something of note as far as tire widths depending intended use. A 30mm diff. in staggered my cause more understeer than desired. A 20mm diff may be more neutral. I plan 285 rear and 265 front when I do go ec-7.
11-25-2020, 07:24 PM | #4 | |
Rep 1,759
Obviously, a square setup on a car with 50:50 weight distribution, both front and rear would degrade at a fairly similar rate so all the tyres would lose grip and slip at around the same time, at the same rate so the handling would be neutral. |
