11-18-2020, 05:41 PM | #1 |
24082
Rep 190,597
INSANE BMW S55 One Piece Crank Hub **NEW PRODUCT**
We are happy to introduce the newest crank hub on the market! Want to add more hp but Worried about spinning your crank hub? We have a Solution! Our Single Crank Hub kits are designed and manufactured in Lithuania and made from a solid block of thermally absorbed, heat treated steel and milled on a 5 axis precision CNC machine to create what we believe to be the strongest crank hub kit on the market today! Our crank hub is offered in a 2 pin and upgraded 4 pin design for those looking push their S55 to the limits while having greater peace of mind. Please keep in mind neither version has had a known failure with 300+ vehicles on the road today and counting. Our crank hub has also been tested up to 1000whp without issue. This kit includes all the necessary components to successfully replace the stock OEM crank hub with our single piece crank hub. Our kit now includes Hardened crankshaft damper bolts at no additional charge. We offer professional installation for our kit at all of our approved dealer locations KIT INCLUDES: Insane Performance CNC'ed Single Piece Crank Hub Upgraded and Reinforced crankshaft Damper Bolts Specialty Drill Bit Drill Bit Fixture Tool For Easy And Precise Drilling INSTALLATION: We suggest that this Crank Hub Kit ONLY be installed by a highly qualified shop and technician. Note: BMW specialty Crankshaft Alignment S55 Timing Tool and flywheel tool are required in order to complete this procedure. Insane Performance will not be liable for Improper installation as it may cause catastrophic engine damage.
11-19-2020, 07:46 AM | #3 |
24082
Rep 190,597
Last I checked, the shops were charging ~ 20 hours
11-19-2020, 12:34 PM | #4 |
Rep 591
At what point does one need to seriously consider this modification? 500hp/tq and beyond etc...?
11-19-2020, 01:00 PM | #5 | |
Rep 772
Ive heard numerous people even complain about spun hubs on stock power but then I've also found those same people to be lying and have actually tuned their car (just didn't want to be caught out for warranty purposes). It's impossible to know for sure. To be safe I would say the general consensus is stick to stock and keep your warranty as long as you can and if you tune, at all, get your crank hub fixed. If not this method, a capture plate at minimum. Anything above stage 1 then go the full hog. |
M2 CCO1083.00 |
11-19-2020, 02:24 PM | #6 | |
24082
Rep 190,597
impossible to tell, if you are extra safe i recommend doing it after the car is stage 2. Most wait till its time for a turbo upgrade
11-19-2020, 08:30 PM | #7 | |
Rep 591
11-20-2020, 07:13 AM | #8 |
24082
Rep 190,597
That's my personal opinion but I have no data to back it up. I have seen this part fail even on stock cars.
11-20-2020, 08:00 AM | #9 |
Rep 1,358
There have been more than a few people who've had crank hub slip with stage 1 tune. It seems to be more prevalent on DCT cars but still happens on manual.
It's an expensive upgrade but the down side is huge. Once it is installed the s55 is extremely robust and takes to large power upgrades very well. |
11-28-2020, 09:07 AM | #10 | |
24082
Rep 190,597
