11-17-2020, 03:09 PM | #1 |
Rep 266
Drives: '89 Land Cruiser, '18 M2
M3/M4 F8x Brakes fit M2?
Hey guys,
One of my favorite mods on my last fun car was rebuilding Cayenne Brakes (18z) and throwing them on my VW Golf R. Although the standard blue is kinda cool on the M2, I think an orange or gold BMW M brake would look great on my Mineral Gray M2. Are there any differences between the F8x M2/M3/M4 brakes from a "fit" standpoint? |
11-17-2020, 07:28 PM | #2 | |
Rep 7,422
Racing brake makes a bracket kit that will simplify your retrofit.
bngcruiser277.00 |
11-18-2020, 01:56 PM | #3 | |
Rep 1,262
Drives: BMW 1M
11-18-2020, 02:03 PM | #4 |
Rep 266
11-18-2020, 02:07 PM | #5 | |
Rep 1,262
Drives: BMW 1M
All still plug and play. I did just that, Fitted the gold calipers with the grey kit steel brake discs. |
kimchee411101.50 |
11-18-2020, 02:12 PM | #6 |
Rep 266
thanks for the help, i'll start diving into all the geometries and such ..
.. this is easier than my cayenne 18z mod. That was a headache with brake booster, correct bracket Mercedes g class rotors, etc. |
M2C_PLUS1774.00 |
11-18-2020, 02:14 PM | #7 | |
Rep 1,262
Drives: BMW 1M
When you buy the grey or gold 6/4pots they come with the mounting bracket fitted. |
11-18-2020, 04:16 PM | #8 |
Rep 7,422
I personally would save the money and buy better aftermarket brakes if you are seeking performance.
But if you are looking for aesthetics then yeah go for it - realoem will help you get the correct p/n's.
ebisu81079.50 |
11-18-2020, 05:00 PM | #9 | |
Rep 266
Just need to set up a budget so I can save effectively, it's how I work :shrug:
11-19-2020, 01:57 PM | #10 |
Rep 1,934
Doesn't the M2 already come with 380/370 mm Brembos front and rear in blue? This is what is standard on M3/4 as well. The Gold and Grey Brembos bump you up to 400/?? Front and rear.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
bngcruiser277.00 |
11-19-2020, 05:08 PM | #11 | |
Rep 478
The 6-pot calipers come in Gold(Carbon Ceramic Packages - M2CS, M3, M4, etc.), Grey (M2C), Blue (M5, M6 - as far as I know these are all the same calipers), and Red (M Performance "upgrade") I'm actually on the hunt for M5/6 calipers, considering the 6pot upgrade. If it's for looks - I'd just consider having someone like IND repaint your calipers to the color you like. The 2NH brakes (6pots) looks like they'll cause more clearance issues. |
11-20-2020, 01:23 AM | #12 | ||
Rep 1,262
Drives: BMW 1M
M5/6 calipers are not the same, they take the same size pads as the gold and grey calipers but they are a different size by 5mm and do not come with oem brackets to mount on M2/3/4 hubs. Image shows the difference below . Last edited by M2C_PLUS; 11-20-2020 at 01:34 AM.. |
11-26-2020, 12:27 PM | #13 | |||
Rep 1,934
11-30-2020, 09:55 AM | #14 | |
Rep 4,515
Fronts https://www.realoem.com/bmw/enUS/sho...diagId=03_0104 Rear https://www.realoem.com/bmw/enUS/sho...diagId=03_0103 HTH, BP
Current '22 X3M LCI.. |
bngcruiser277.00 |
