11-15-2020, 12:36 PM | #1 |
Rep 7,408
Would this ebay wheels fit?
So I have winter tires in OEM 19" sizes. I found out there is rep 763 wheels on ebay.
I was wondering if this wheels would fit m2 (for winter only) This is the size Front - 19 x 8.5 ET40 Rear - 19 x 9.5 ET45 The tires I have 245/35 and 265/35 in 19 And I have OG m2 |
11-15-2020, 07:18 PM | #2 | |
Rep 1,092
The inside clearance would be about 5mm smaller than OEM in the front but I think they would clear. The inside rear would be pretty much stock. But the outside would be 17mm deeper into the wheel well in the front and 11 in the back. It would have that "Mustang" look with wide fenders but narrow wheels. I run 720form GTF2 18x9 ET30 and they fit quite nice. |
11-18-2020, 08:16 AM | #4 | |
Rep 478
OEM Is 19x9 ET29 Front, 19x10 ET40 Rear. |
11-18-2020, 01:38 PM | #5 |
Rep 1,092
11-18-2020, 01:40 PM | #6 |
Rep 1,092
Yes, but if you add the cost of good quality spacers and longer bolts you might be able to find better fitting wheels for the same money.
If you are looking at CM Wheels then they sell the replica with 20 and 30 offsets which would be a perfect fit. Last edited by mr_lab_rat; 11-18-2020 at 01:47 PM.. |
11-19-2020, 10:14 AM | #7 |
Rep 13
I tried some rep like those but I have the 2NH M brake option on mine.. and not enough inside clearance for the brake caliper.
As for the spacers.. you could see after what to do. If you want or not. But with the big brakes from BMW... I think that only maybe in 20".. and not certain. I return them. Still got the OEM M2C wheels on it. Donīt know what to do... yet. |
11-19-2020, 10:27 AM | #8 | |
6632
Rep 4,145
Drives: '18 M2 6MT
If you'd like it to look more like stock, just get a 15mm spacer for the front, and 10mm spacer for the rear. |
