10-31-2020, 06:30 AM | #1 |
Rep 986
Drives: 2024 M4 Comp X-Drive
305/35/18?
Hi guys,
On a stock suspension 2018 M2 can you fit a 305/35/18 in the rear? If so what offset / wheel width would you recommend? I'm considering a lightweight 18 inch setup for the car and would like to go wide in the back for as much traction as possible. (Likely 255/35/18 in the front if it'll fit)
2024 Dravit Grey M4 Competition X-Drive
11-05-2020, 04:27 PM | #2 |
3525
Rep 6,752
A 305/35-18 likely will not fit without a healthy amount of negative camber and possibly need rolled rear fenders depending on the exact tire chosen. A 285/35-18 or 295/35-18 would be a better option if running stock suspension and alignment settings.
If trying to run an aggressive staggered setup, I would recommend a fitment similar to the one listed below with stock suspension: Front: 18x9.5" ET28 Rear: 18x10.5" ET40 A 255/35-18 front tire should fit no problem. If you sized up to a 265/35-18 you may need a little negative camber up front. A 285/35-18 or 295/35-18 rear tire should also be ok. This is all assuming that you have the smaller brake package. No 18" wheels can clear the 400mm 2NH brake setup. -Ian
11-05-2020, 05:35 PM | #3 | |
Rep 986
11-05-2020, 05:57 PM | #4 |
381
Rep 731
Could you please explain what a smaller brake set-up is?
At a Point above 7,000 RPM.
11-09-2020, 07:32 AM | #5 |
Dom
1080
Rep 1,718
The M2C has the whopper of 400mm brakes that don't allow for 18" wheels. At least that is standard in the US. The rest of the world has the option to get the standard blue brakes which are 380m.
chief1richard381.00 |
