10-31-2020, 03:50 PM | #23 | |
Rep 147
The flutter is at low rpm and is the diverter valve. I will see about increasing the gap and if that makes a difference. The hesitation is getting worse though an feels like a jerky gear shift. This might be because the plugs gap has changed |
10-31-2020, 04:10 PM | #24 | |
Rep 7,422
low rpm and load flutter is inevitable with how these diverter valves work. You should also buy new plugs as well, excessive misfires can damage the plug insulator which can cause it to drop into the cylinder and that is a big issue.
10-31-2020, 07:03 PM | #25 | |
Rep 147
ye
10-31-2020, 07:09 PM | #26 | |
Rep 7,422
But overall it's hard to tell if the tune is the only cause as you did alot of mods at once. Also tell your mechanic the stiffening plate bolts are single use, since he had to have taken that off for the turbo smart bov install.
11-01-2020, 03:59 AM | #27 | |
Rep 147
I will pass the info. I know he has some form of ista so I will get him to check it |
11-01-2020, 12:40 PM | #28 |
Rep 7,422
Hmm interesting, what mods did you do before the issues cropped up? But overall it could be tune related, is your tuner an ecutek master tuner?
11-01-2020, 02:34 PM | #29 | |
Rep 147
The turbo was making a noise like a supercharger and failed while the garage was testing it. Apart from the noise that I though was a boost leak there was no problem it was running spot on |
11-01-2020, 02:57 PM | #30 | |
Rep 7,422
11-01-2020, 03:12 PM | #31 | |
Rep 147
How do I upload files properly on here Last edited by boldy1; 11-01-2020 at 03:19 PM.. |
11-02-2020, 02:28 PM | #33 |
Rep 7,422
That's good, it means there are no minor issues that can be the culprit. But it also means the misfires are so minor it doesn't trigger ecu codes.
I would address plug gaps first, and of course the fuel injector o rings and decoupling elements as well. If that doesn't fix it that could mean the tune. Again it's hard to tell over the internet, and not being the one that did all the mods.
11-02-2020, 03:30 PM | #34 | |
Rep 147
I was speaking to a tech earlier that said it could be a faulty injector or loom that is causing the issue. He also said that it might not be the one the misfires are happening on. Or possibly the injector loom. Another thing that has been mentioned by the garage is that the wagner sports cat is full from the oil from when the turbo went and or possibly the lamb sensor. |
11-02-2020, 03:58 PM | #35 | |
Rep 7,422
If you moved the injectors previously and the misfires did not follow then it would be more likely to be the wiring than the injector itself, although wiring issues are not common it is possible. Yes that could also be the issue - oil destroying the oxygen sensor. I would suspect afr readings to be weird if that was the case. If none of that addresses it, then you will probably have to do a compression test which is a nightmare scenario as that is essentially seeing if you engine has blown.
11-02-2020, 04:24 PM | #36 | |
Rep 147
11-02-2020, 06:02 PM | #37 | |
Rep 7,422
Again it's hard to give any meaningful diagnostics over the internet without seeing the car in person, seeing the issue, and know what has been done to it. All I can say is hopefully your shop can fix it, but I hope we helped a bit in this thread by giving you updated plug gaps, catching injector seals and decoupling elements.
11-03-2020, 03:10 AM | #38 | |
Rep 147
It will help and any advise is a start and builds on your knowledge. |
11-25-2020, 06:12 PM | #39 |
Rep 147
Update on this issue after swapping injectors. New plugs new coils new lamba sensors switching Tmap sensors. Compression testing logging head scratching and general getting pissed off the problem has been solved.
Its the setting off the xdi35 more precisely the low flow settings that are causing the issues and I believe that this same issue is what is plaguing many other m2s around the place. Thanks to my tuners and ecutek the issue with the pump has been sorted 👌 no noise no misfires nothing. We knew the was a issue with the low flow all along and with most your cars you won't even notice it's there. But there is a solution avaliable now the Dorch is being worked on too. I thought I would mention it as there is nothing with a positive outcome posted |
F87source7245.50 nothingman522.00 |
11-25-2020, 06:32 PM | #40 | |
Rep 7,422
I'm also glad to hear you solved the issue, darn HPFP upgrades it seems to be a huge plague with tuning recently.
11-25-2020, 06:49 PM | #41 |
Rep 147
07-22-2022, 02:52 AM | #42 | |
Rep 34
Edit: Seems like it went away. I only get a little hick up/stumble when I punch it in 2nd gear. One thing I notice is if I’m at idle, I give it a little rev and it seems to break up. Possibly plug gap related? I’m going to try the .28 you recommended. Thank you Last edited by Leaveatrail86; 07-22-2022 at 05:28 PM.. |
