10-29-2020, 09:31 AM | #1 |
Rep 266
Drives: '89 Land Cruiser, '18 M2
Scrub Radius
Hey guys,
This is the first time I am making adjustments to my wheels/tires/suspension and actually worrying about what it is going to do to my vehicle (amazing right)? A little background: 2013 WRX - Lowered on KW V1 Coilovers w/ stock wheel geometry 2014 STI - Lowered on KW V2 Coilovers w/ .5" wider wheel/tire geometry 2013 VW R - Lowered on KW V3 Coilovers w/ 1" wider/taller wheel/tire geometry 2018 BMW M2 - Lowered on KW V3 Coilovers (Looking to go: 19x9.5 et23 fr and 19x10.5 et34 Rr, MPSS 245/265) I have been introduced to scrub radius for the first time during my research and I want to try to gain the best understanding of it. This site has been a great resource as I have been trying to decide on the geometry of wheels to go with: https://www.wheel-size.com/calc/ I am looking to try and achieve a zero scrub radius relationship with the new wheels and rubber - the question I have is, can I affect the relationship by introducing camber/toe-in? I have Ground Control Camber Plates installed with my KW V3 Coilovers .. and if I am understanding the relationship correctly, I can add/subtract camber to influence the scrub radius along with increasing/decreasing the height of my Coilovers. Thanks for any assistance .. I know I just asked a bunch of questions and introduced a ton of variables. Cheers |
10-30-2020, 05:25 PM | #2 |
Rep 70
Found this on YouTube - a lot of great alignment information including scrub radius covered.
bngcruiser277.00 |
11-02-2020, 06:50 PM | #3 |
Rep 1,092
You can completely skip all this. I don't know what the scrub radius of the stock suspension is but by going from 9" wide wheel with ET29 to 9.5" wheel with ET23 the centre of the tire remains in the same spot (because you are essentially adding the same amount of wheel/tire width on the outside as you do on the inside).
I'm running 15mm spacer and 1.85 degree camber with stock wheels and I'm not noticing any negative effects. |
11-02-2020, 10:46 PM | #4 | |
Rep 266
Not sure, maybe this is wrong:
11-03-2020, 05:15 AM | #5 |
Rep 3,315
Yeah, it was wrong. Scrub radius isn't affected by wheel width but only by the offset value since that determines the location of the center of the tire (and contact patch). Notice how the calculator showed the scrub radius changed by exactly the ET (offset) change in the result.
Current Stable:
bngcruiser277.00 |
11-03-2020, 07:06 AM | #6 |
Rep 266
The video was very helpful.
11-05-2020, 12:24 PM | #7 |
Rep 266
Continuing to try and better determine how adding positive scrub radius will affect the vehicle tracking down the road.
Does anyone know what our OEM Spec Scrub Radius for our vehicles? As a RWD vehicle, my understanding is we probably have positive scrub radius from factory with some toe in on the back. I will be adding roughly 6mm of positive scrub radius, which will mean needing to add more toe in to keep the vehicle from changing the driving dynamics by a bunch. |
