07-17-2018, 05:49 AM | #1 |
General Moron
247
Rep 158
Work Meister M1 on an M2
19 x 9.5 Front, 19 x 10.5 Rear. Centre caps are on order so should arrive in the next day or so
8
Bee Pee1778.00 AndrewC198910931.00 QM287.00 BLUE-BEAST///M247.00 dtmpower98336.50 bunnyhive55.50 COChris888.50 rogeroger73.00 |
07-17-2018, 06:48 PM | #3 |
Da Baus
283
Rep 259
Looks very mean. What suspension setup
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
Peasley247.00 |
07-18-2018, 10:11 AM | #5 |
Rep 4,551
Drives: 2015 328d xDrive
Not a huge fan of the wheels but I think you did a really good job mixing and matching all of your aero.
Mode carbon lip, perl side skirts, ebay mirror caps, MPE rear spoiler...looks dope AF. |
Peasley247.00 |
07-18-2018, 10:43 AM | #6 | |
General Moron
247
Rep 158
The spoiler is actually a PSM Dynamic so it's a proper mix of brands |
AndrewC198910931.00 |
07-18-2018, 11:50 AM | #7 |
Doc Brown
1176
Rep 2,174
Also, if you want that real race look, leave the center caps off
Sundinisagod107.00 |
07-18-2018, 01:59 PM | #8 |
Rep 4,551
NYC Bimmer259.50 |
07-18-2018, 03:07 PM | #9 | |
Doc Brown
1176
Rep 2,174
Obviously to each their own, but to me it gives a little character to a otherwise clean car.
07-20-2018, 03:24 PM | #14 |
General Moron
247
Rep 158
Full specs are as follows:
Work Wheels Meister M1 FRONT Wheel Diameter 19" Wheel Width 9.5J Offset 24 PCD 5x120 Disk Type R Disk (Big Caliper) Colour Standard Silver Rim Colour Standard Polished Bolt Colour Standard (Chrome) REAR Wheel Diameter 19" Wheel Width 10.5J Offset 43 PCD 5x120 Disk Type O Disk (Deep Dish) Colour Standard Silver Rim Colour Standard Polished Bolt Colour Standard (Chrome) |
tenkies147.00 |
10-08-2018, 03:10 AM | #17 |
Rep 1,092
At 9.5 ET24 the fronts are sitting 11mm farther out than stock which is pretty much flush when lowered.
10.5 ET43 is just 3mm wider so 6-8mm spacer would make it look right. |
10-08-2018, 04:58 AM | #18 | |
Rep 8
Im currently on F: 10 et20 and R: 11 et29 Last edited by AvoryM2; 02-19-2019 at 08:48 PM.. |
10-08-2018, 08:16 AM | #19 |
General Moron
247
Rep 158
Cheers mate. Yes currently there are 10mm spacers on the rears from my stock wheel setup. It pokes the rears out a bit more than I would like so looking to get some smaller spacers soon
10-08-2018, 08:54 AM | #20 | |
Rep 8
Thanks again mate... Btw do you have instagram page to follow? |
10-08-2018, 09:45 AM | #21 | |
General Moron
247
Rep 158
If memory serves me correct I went with the O disc on the rear in order to run a deeper dish. Driftworks (UK distributor for Work) helped me spec the wheels and followed their advice. No Instagram currently but time will tell |
10-08-2018, 12:02 PM | #22 | |
Rep 8
Also keep us update if you can clear with less mm spacer. Im looking to get o disc as well but with 5mm maximum Thx again mate |
