04-19-2024, 10:58 AM | #1 |
9604
Rep 10,891
IND | Fall-Line Motorsports F87 M2 Adjustable Sway Bar Links - Pinch-Nut Fasteners
MADE IN THE USA Lowering your car is often the first step in suspension tuning, but occasionally, this process can adversely affect other associated components. Unwanted sway bar pre-load may be one of these consequential effects, adding asymmetrical spring rate bias to one side of the car versus the other. This imbalance may affect your overall chassis dynamics and corner balance. For this reason, adjustable sway bar end links are critical—by adjusting each link with the car at operating weight, you can ensure the sway bar is completely unloaded at your determined ride height, restoring your chassis' balance and your confidence in all driving situations. Unlike all other link kits on the market that utilize the cheaper and simpler jam-nuts, Fall-Line's new V2 utilizes OE tie-rod end style pinch-nut fasteners to ensure they never lose their set length. V2 Key Features:
The Fall-Line Motorsports F8X M2 / M3 / M4 Adjustable Sway Bar Links - V2 may be viewed at the following link to our online store: Front: https://ind-distribution.com/product...r-end-link-kit Rear: https://ind-distribution.com/product...r-end-link-kit Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
