02-13-2019, 04:48 PM | #3 |
Rep 1,823
Nothing good. You need right air/fuel ratios, boost, fueling and timing to run properly. If you have more compression without the right tune you can hurt your engine components. Bad idea in an EPIC way.
2017 BMW M2 German Spec
02-13-2019, 07:33 PM | #4 |
Rep 2,526
As others have said. Bad idea. Go FBO first, then do turbo.
It's a couple grand to go FBO if you do the work yourself. Worth it for the longevity of your vehicle. |
02-14-2019, 01:10 PM | #5 |
The deuce gets loose
290
Rep 499
This is like buying a primed bumper and installing it on your car while you can't afford paint. Don't do it. You need paint in this case (a tune).
02-18-2019, 08:50 PM | #6 |
Rep 2,577
Welcome to M2 club.
Hear this - Yes - you would be running just fine with bigger turbo (presumably the hybrid type) and nothing else needed. No CEL, no limp mode, no nothing. And boost/ignition/AFR spot on. Car will be rock solid. If anything, it will run cooler and more efficient, but spool up time will be longer and torque band will be shifted to upper range a little. That being said, a tune and the supporting hardware (especially the intercooler) can make bigger turbo really shine where it can.
Lemania 2320
ZM22810.50 |
02-19-2019, 09:04 AM | #7 | |
Rep 1,823
02-19-2019, 09:29 AM | #8 |
Rep 3,695
Related but different question:
When you have a larger turbo, is there really any point in flashing BM3 back to stock when you take the car to the dealer for service? Seems like if you have an issue they’d just blame it on the hardware, even if the software is “stock”. |
02-19-2019, 11:06 AM | #9 |
Rep 2,577
5.MONSTER, yes correct.
ZM2, it's very difficult for the dealer to tell hybrid turbo from stock one without taking it off. Meaning, I'd flash back to stock prior to the dealer visit, provided you do have a drivetrain problem. Damn...In the past 2 years, I installed bigger turbo twice, put 15k miles on them, did 5 hard track days with them. And I have yet to see a single CEL! Talk about N55 reliability and the art of tuning.
Lemania 2320
ZM22810.50 |
