01-25-2019, 07:31 AM | #1 |
Rep 202
Battery power for dash cam
Just installed a BlackVue cam with parking mode. Per BlackVue recommendations I got the power magic pro with it. The shop that installed it said it wasn’t necessary. I park in a busy parking garage every day and the camera is recording a good bit of video while parked. Do you think it’s ok to forgo the power magic pro?
01-25-2019, 08:42 AM | #2 |
Rep 1,336
Depends on how often and long you drive the car for. With my BV DR900S it will drop the voltage to 12v (cut off) in about 4-5 days if not driven and this is on a new BMW M2C ie: new battery.
If you have it why not use it?. |
01-25-2019, 09:03 AM | #3 | |
Rep 202
There are times it sits 3-4 days when I’m off but not usually longer than that and I can plan to turn off parking mode when I’m out of town. I hope I don’t forget. |
01-25-2019, 04:10 PM | #4 |
Da Baus
283
Rep 259
Yes you should have it it installed, there is no reason not to. Its added protection and at some point in your ownership it will bite you in the rear for not having it. Then you can 'set it and forget it'.
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
