10-23-2018, 12:31 PM | #23 | |
Rep 269
10-25-2018, 03:38 AM | #24 |
Rep 540
Just to throw a potentially related thing into the mix ... My M4 has been delayed at the last moment, BMW are doing so as a precaution but it has something to do with needing to fit a new crankshaft position sensor....
10-25-2018, 09:58 AM | #25 |
Rep 538
I'm wondering if the spline lock fix is better than the keyed solutions or not. The keyed solutions look logically like a better solution but I can see how using essentially a reversed "EZ out" would keep it from moving as well.
It just seems like the keyed variants are machined to an exact lock position where the spline lock is basically digging into material to hold it. |
02-12-2019, 03:07 PM | #26 |
Rep 6,634
I was wondering about this. Why did they retune this? If it was to reduce chance of SCH I would think they would also tune all the DCT M cars this way with the latest update, but I don't think they have.
02-12-2019, 10:34 PM | #27 | |
IG @bmwF9xG80
3812
Rep 7,592
Also these folks over at EAS have done a few Spline Lock https://f80.bimmerpost.com/forums/sh....php?t=1561598
60-130mph 6.5s X4M #HCP
02-13-2019, 12:36 PM | #28 | ||||
Rep 1,262
Drives: BMW 1M
02-13-2019, 01:09 PM | #29 | |||||
Rep 1,237
Drives: M2 Competition
02-13-2019, 02:18 PM | #30 | ||||||
Rep 1,262
Drives: BMW 1M
02-13-2019, 04:20 PM | #31 |
Rep 538
02-14-2019, 03:02 AM | #32 | |
Rep 1,262
Drives: BMW 1M
It only needs to loosen enough for the timing sprocket to move 3mm and thats the timing out and limp mode. See the image of the damage to my timing sprocket. Those marks are only around 3-4mm long, enough to throw the timing out only. I was cruising at 45-50mph in top gear when mine went. So very lucky. |
FSociety3811.50 |
02-14-2019, 08:14 PM | #33 | |
Rep 538
02-19-2019, 02:58 PM | #35 |
Rep 538
02-19-2019, 03:04 PM | #36 |
Rep 8,972
Agree - fitting just the bolt capture plate seems an easy job and if it stops the bolt coming loose that's good. but.....
There are multiple areas that movement could occur. The friction washer sits only between hub and timing gear see https://www.realoem.com/bmw/enUS/sho...diagId=11_5597 1. The timing gear could slip on the hub (less likely due to friction washer between them) 2. The hub could move against the crank moving the timing gear with it. If the hub turns then this may turn the bolt with it maybe loosening the clamping further 3. Both of the above at the same time The vibration damper is very heavy and this puts a lot of rotating mass on the hub. Last edited by doughboy; 02-19-2019 at 03:29 PM.. |
Proctor750426.00 |
02-19-2019, 04:54 PM | #37 | |
IG @bmwF9xG80
3812
Rep 7,592
There's a PS2 F80 M3 with Meth and E50 fuel running over 15,000 miles on that bolt capture ($100 piece) since August 2017 after he spun oem hub twice w/o any preventative protection. Now VTT released a Spline Lock Hub (full fix, and only one that does not require drilling unlike Gintani/Maxpsi hub) More options better for the platform
02-19-2019, 05:10 PM | #38 | |
Rep 538
$100 bolt capture vs $800 hub + 20 hours of labor.... I may just spring for the capture and hedge my bets no? I wish there was more data on people using just the capture piece. If it provides even 80% success rate vs the 100% of the full spline lock option - at $100 bucks you are hitting diminishing returns with the spline lock. |
02-19-2019, 05:27 PM | #39 | |
Rep 8,972
We don't know for sure if the bolt is coming loose, or if the hub slips while the bolt remains static and in factory position. Either way the bolt capture locks them both together which will greatly increase the torque load required to slip the hub and bolt "as one" and will prevent bolt movement on its own. |
02-20-2019, 01:15 AM | #40 | |
Rep 538
Its starting to sound like a high rpm resonance thing and not so much HP related. It's extremely unusual to me that a 100% demonstrable culprit has yet to be agreed on with such an obvious sampling of incidents. I guess diagnosis isn't pursued and as in many other things the attention is given to the symptoms and not the actual cause. |
02-20-2019, 01:36 AM | #41 | |
Rep 1,759
02-20-2019, 01:42 AM | #42 | ||
Rep 3,659
Drives: 981 Cayman GTS
02-20-2019, 01:52 AM | #43 | ||
Rep 1,262
Drives: BMW 1M
Having seen an S55 engine on a bench dyno the damper rotation is far from smooth and is only exaggerated as RPM's increase. |
02-20-2019, 03:16 AM | #44 |
Rep 8,972
They call it a "damper" but in my experience they are just a big heavy metal lump of a pulley, a mini flywheel on the front of the crank. No flexible parts are there. It's meant to dampen out torsional (twisting) vibrations in the crank.
Looking logically, a sudden increase in (clockwise) crank rpm would place a strong anticlockwise (ie undo right hand thread) force on the hub. Conversley a sudden decrease in rpm would apply force to tighten the hub. This may go some way to explaining the slipping on it money shifts and kickdowns. Also higher frequency back and forth twisting oscillations will put a lot of stress on the hub assembly. These will increase with engine torque at any given rpm as extra torque directly applies force at every firing stroke to the crank causing flex that the damper has to damp. BMW will have tested this for sure, but only for their designed torque ranges. Checking on TIS the centre bolt (TTY stretch bolt) is tightened to 100nm plus 270deg. Also it says to oil the thread and no thread locking compound is used. So the assembly relies on the friction of the hub/gears/crank faces only. Oiled threads will clamp much tighter at a given torque however. It says should be over 600nm to remove. For 99USD plus shipping the VTT bolt fix seems a good start. Last edited by doughboy; 02-20-2019 at 09:22 AM.. |
FSociety3811.50 |
