09-06-2017, 01:20 PM | #1 |
9587
Rep 10,877
IND | Fall Line Motorsports F87 M2 Toe Link Kit
A byproduct of multi-link suspension arrangements is a dynamic change in the car’s alignment settings- when making an adjustment to one attribute, such as camber, track width and toe will follow. This is especially true for the F8x vehicles, as the original BMW camber eccentric bolt has a major impact on toe as well. Alignments are made faster and simpler when using a set of aftermarket lower arms, enabling the alignment tech to easily reset toe after adjusting camber. The Fall Line Motorsports F87 M2 Toe Link Kit is designed to facilitate rapid adjustments of toe during an alignment, and combined with the tension strut will also enable adjustment of overall track. Not only does this allow for fine tuning of wheel fitment, these arms will allow an alignment shop to make quick work of car setup, even simplifying the camber adjustment process as a result. The Race version of the toe link kit utilizes a unique clamp-style fastener system as seen in BMW’s own tie rods and Porsche Motorsport components, tightening the adjustment arm in place with no stretch of the hardware or change of alignment. Less expensive jam-nut designs limit precision and nearly guarantee an alignment change when the jam-nut is tightened. As will all Fall Line suspension components, high quality Aurora bearings are used to ensure a very long service life. ARP hardware is used throughout to guarantee the highest level of durability. Laser cut lockout washers correctly eliminate the original BMW adjustment, eliminating any unwanted movement in the system. The Fall Line Motorsports F87 M2 Toe Link Kits may be viewed here in our online store: https://ind-distribution.com/product...M-F87-1FECOTOE Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com Street Version: Race Version:
