08-28-2018, 12:40 PM | #1 |
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
Stage 2 OTS Map (91 oct) - Dyno results
Just dyno'd my car. It's a 2017 BMW M2 running BM3 OTS Stage 2 map (91 oct, v5.4). My car has a catless Wagner DP and Wagner Evo 2 comp FMIC. Gas was WA state pump gas, 92 oct. Stock M2 will dyno around 330whp/380-390 ft/lbs for comparison. Thoughts? Car gained +35whp and +10 ft/lbs going from stock to stage 2.
EDIT: These dyno pulls were done in 5th gear (DCT) and in "dsc off" mode. Last edited by 425M2; 08-28-2018 at 03:14 PM.. |
08-28-2018, 01:02 PM | #2 | |
Rep 132
2011 BMW X1 28 (sold)
2013 BMW 328 Sportline (sold) 2018 BMW M2 LCI (current) |
08-28-2018, 03:12 PM | #3 |
Rep 112
08-28-2018, 06:20 PM | #5 |
Rep 24
[QUOTE=GerardzM;23652387]Octane is definitely killing it for you.
This is a FACT! I've been through a lot of Lucas octane boost and data recording on my M240i and the M2. Such a BIG difference when I mix 91 and 100 for a 92.0 octane blend on the stage 2 91 map. I have found that CA 91 premium gas is really 89-90 at best. Ordering a drum of Torco 108 today - 7-3 ratio will make the M2 happy on the BM3 Stage 2 93 Map... I know. |
08-28-2018, 07:00 PM | #6 |
Rep 2,700
+3 about octane
I've tried a lot of things in my M235i and the best results were when I mixed real race gas in.
08-28-2018, 07:25 PM | #7 |
Rep 2,577
You guys are crazy. It's very unlikely to be the octane issue (or any issue at all), since OP is running 92oct on 91 map. Things worth asking are ambient temp, humidity. Which seems also normal as power/torque curves shows from his dyno plot.
Pay attention to correction factor of SAE, switch to STD, which is what Bimmerpost guys prefer, instantly power/torque figure bumps up by 10 whp. There is another 10+whp or so in 93oct map, which makes around 390 with correct octane and properly performed dyno runs. I'll say op absolutely put down strong numbers already.
Lemania 2320
08-28-2018, 09:03 PM | #8 |
IG @bmwF9xG80
3813
Rep 7,593
If you didn't dyno your car stock then you have nothing to compare to!
Stop thinking every car is the same
60-130mph 6.5s X4M #HCP
08-28-2018, 10:46 PM | #9 |
Rep 931
Great numbers OP. You need a stock dyno from their to compare to, you should’ve switched maps while there. We all use STD correction with BMWs on the forum. Yours is SAE which always reads lower than STD from what I’ve seen myself on my own car and others.
08-29-2018, 08:13 AM | #12 | |
Rep 2,577
You can push harder at around 5k5 running at fueling limit if octane supports, for like 10~15whp more in peak. Not worth it. I can see OP will have power at 6k~7k when the ambient temp goes lower.
Lemania 2320
08-29-2018, 03:26 PM | #13 |
IG @bmwF9xG80
3813
Rep 7,593
Not sure if you realize but 91-92 are the same.
In some North East states for ex Wawa they carry 92 but everything else says 93. So it ends up being some 93 are actually 92ish. That's why I run 1-2 Gal of E85 on my 93 map got added safety. If I want to run more then I switch to E30 map
08-29-2018, 04:14 PM | #14 | |
Rep 390
My fault for assuming the same for OP. I couldn't fathom being stage 2 on 91 with the fuel I have access to. Damn car already pulls timing bad with the stock tune. |
08-29-2018, 05:10 PM | #15 | |
IG @bmwF9xG80
3813
Rep 7,593
Octane quality varies so the tune takes effect to that and will lower or increase numbers. Doesn't necessarily means its always pulling timing But if there's heat + low octane it will not give you all the power to keep itself safe (Smart) Also since there's no logs provided by the OP we dont know anything If he can provide us the drf files I'd be happy to upload a web graph that display the Temps / etc and STD form, etc I really urge anyone and only suggest to Dyno when you can do a Stock Pull at the end of the runs with 10-15mins cool down. PS.. Mistakes I did in the past but learned
425M270.50 |
08-29-2018, 08:26 PM | #16 |
Rep 112
Thanks for everyone’s feedback! Some good info in here. Some of you have suggested trying the E30 map, I was under the impression we can’t run an Ethanol mix that high on stock fueling? Thought E15-E20 was the max that we could run.
08-29-2018, 08:36 PM | #17 | |
IG @bmwF9xG80
3813
Rep 7,593
E25-E30 is what typically M2 EWG tolerates on the E30 OTS Logging Wide Open Throttle 3rd gear 2500rpm will and full 4th gear will tell you if you can run what and where
425M270.50 |
08-29-2018, 09:13 PM | #18 | ||
Rep 2,700
I know all MT its 3rd
08-31-2018, 12:37 AM | #19 | |
IG @bmwF9xG80
3813
Rep 7,593
After I do this I then test my 100-200 (EU) or 62-124mph times with Dragy to see the improvement etc
