05-03-2016, 03:39 PM | #1 |
Rep 150
Intake Tune Exhaust
so just wondering can I get an intake from the m235 and it direct fit and what JB4 do I look up to buy also just want to double check before buying parts
05-03-2016, 04:17 PM | #3 | |
Rep 796
Comes down to sound vs power |
05-03-2016, 10:35 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
IND tested it out and it uses paper filter
60-130mph 6.5s X4M #HCP
05-03-2016, 10:44 PM | #5 |
Rep 796
I guess that's what I meant by dry. Paper dry haha. Different than some I assume.
05-04-2016, 09:51 AM | #7 |
Rep 4,516
Hardly, Mr.5 was an extra hole with ducting to a dedicated filter that added much more cold air into N54 air box.
M2 lower airbox is the same as F30 N55 MPPK lower airbox ie big red hole directly behind LH headlight. I tried F30 MPPK airbox on M135i with Jb4 and found it added nothing compared to std N55 airbox and a drop-in. I swapped back and installed an AFE DAS behind LH grille to help direct air into airbox, adding positive pressure to help flow thru an AFE dry drop filter panel. In mine and others have found DAS helps throttle response and even adds something to keeping IAT's in check. Great $50 mod for the sealed lower airbox
Current '22 X3M LCI.. |
05-04-2016, 11:31 AM | #8 | |
Rep 796
Thanks for the response! What I meant by Mr. 5 is that it has a whole in the airbox like that intake. It doesn't have a dedicated filter but it helps direct more air into the airbox. It wouldn't be there if that wasn't the case. |
05-04-2016, 11:39 AM | #9 | |
Rep 796
If you have a Pure stage 2 or something similar that's a different story. |
05-05-2016, 02:30 AM | #10 | |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
05-05-2016, 03:24 AM | #11 | |
Rep 4,516
Stick with hole in the airbox fella, given its OEM for more intake noise an M2 !!!
Current '22 X3M LCI.. Last edited by Bee Pee; 05-05-2016 at 04:14 AM.. |
05-05-2016, 04:15 AM | #12 |
Rep 4,516
The YT embedded in my post above may help your decision......
05-05-2016, 04:28 AM | #13 | |
BMW Fanatic
331
Rep 1,076
Edit: Also going withAFE open air intake extremely soon.
