11-22-2019, 03:58 AM | #133 | |||
Rep 472
11-22-2019, 04:13 AM | #134 | |
Rep 7,422
But to answer your question it's the kick down when accelerating. If you press down on your pedal you can feel a really linear travel to the floor, then the last couple of mm you feel a little click or point of higher resistance where if you press a bit harder you can feel the pedal give just a bit more. When the pedal passes that point upon full throttle acceleration it will drop a few gears depending on rpm etc, initiating a kick down. This is what causes alot of stress on the hub and is the most common or attributed cause of the hub slipping. Decelerating and downshifting does put stress on the hub, but if you do it a gear at a time (give it a bit to rev up and slowly decline in rpm like you'd do in a manual) the stresses shouldn't be high enough to spin the hub, as shown on the n54 and n55 where spun hubs are essentially unheard of. If you have a manual for example and go from 6th gear at 1500 rpm and shift it directly to 4th and dump the clutch it would probably be the same stress as a kick down.
11-22-2019, 04:53 AM | #135 | |
Rep 24
11-22-2019, 09:05 AM | #136 |
Rep 7,422
Yeah I would avoid it, you can buy a kick down blocker that prevents the pedal from entering the kick down range. This way you can slam the throttle into WOT position without worry.
11-22-2019, 06:52 PM | #139 | |
Rep 7,422
Sure it's stressful for the drivetrain but it is factored into the overall equation when engineers design the car, so it should be a non issue at stock power levels, with the exception in this case being the s55 since the hub is a known issue.
11-23-2019, 03:24 AM | #140 | ||
Rep 472
If i tune the 500hp map and the Hub fails can BMW then say it's because the car is tuned when they have a GTS with the same s55 engine with the same Hub 🤷🏽*♂️ |
11-23-2019, 03:34 AM | #141 | |
Rep 7,422
Keep in mind the GTS is also at risk of spinning the hub too, there is nothing special about it that prevents the crank hub from failing. Yes if you tune the car bmw can deny warranty if the hub fails, they can make the argument that the gts was factory tune and had parts like water injection etc that was designed to support the power and the m2C does not which is why the failure occured and there is pretty much nothing you can do.
01-06-2020, 05:34 AM | #142 | |
Rep 205
01-06-2020, 05:46 AM | #143 | |
Rep 8,970
It is a single use TTY stretch bolt, so it doesn't even have a final torque setting. On a new assembly, you torque it to 120nm then turn it a further 270degrees, which will probably be over 500nm+ but you will never know . BMW TIS notes warn you'll need over 600nm to undo it. |
01-06-2020, 07:18 AM | #144 |
104
Rep 1,715
I agree it’s definitely the kick down. I haven’t used it at all, but accidentally did for the first time last night and the torque is notably mote instant and violent, especially with my tune. Manual mode only from now on.
01-06-2020, 10:53 AM | #145 |
Rep 538
I would love to know the per unit cost savings to BMW as a result of switching from the tried and true keyed single piece hubs....and the guy who authorized it.
What if his hub spun? Was the promotion worth it? |
01-06-2020, 01:31 PM | #146 |
Rep 7,422
If that's the case then that's my mistake, in the CBC threads I keep hearing the crank bolt was retorqued before install. I may have been mistakened and the bolts holding the CBC was retorqued, I am not sure and must check again.
01-06-2020, 08:39 PM | #147 | |
Rep 1,027
I rarely do it but its the cars best feature that allows you to truthfully express and experience the real potential of the engine DCT is objectively a more sterile experience than MT. Flappy pads suck. Kickdown (that last accelerator pedal bit after the notch) is the only thing a DCT is better at than the Manual when trying to create explosive power and acceleration. Like you can't expect people not to use kickdown. I've done it on every BMW I've owned and/or driven. If you've never done it, please try it, you don't need a 600hp tune to feel fast, just do kickdowns until warranty expires |
01-07-2020, 12:24 AM | #148 | |
Rep 7,422
However that being said I do understand why it is so much fun, but it has been linked to the crank hub slipping since it's so aggressive in how in dumps multiple gears instantly. Overall there isn't really anything you can do about it, the kick down causes issues with the crank hub and it's really a gamble Everytime you use it. Whether or not it causes issues overtime remains to be seen, so if you don't plan on keeping it after the warranty then just go wild. Or if you have the n55 m2 you should be ok, since I've yet to hear this occur on the n55 or n54 motors with the auto or dct kick down.
01-07-2020, 01:18 PM | #149 |
Rep 1,078
Forgive my ignorance as I've been driving stick my whole life, but is a kickdown essentially "flooring" it when you are in a high gear? I was considering DCT for my next car, but this has me second guessing that decision. So as long as you are only flooring it from a stopped position, then this can be avoided? What happens if you want to pass someone aggressively on the highway?
01-07-2020, 01:24 PM | #150 | |
Rep 3,256
From a 6MT standpoint it's like driving in 6th gear at 55 mph, then dropping the transmission/clutch to 2nd gear with the pedal on the floor. Most of us don't drive like that, so it's generally not an issue for us 6MT people. |
01-07-2020, 01:30 PM | #151 | |
Rep 251
the kickdown is a system you activate with a button. the button is in the final mm of the accelerator pedal. if you try, with the car switched off, you will feel a king of resistance at a certain point.if you press with more force you will feel this botton or switch. when pressed it send and imput to the engine telling that you require the maximum acceleration. to achive this acceleracione the engine whille adding boost downshift as much as possible. it could be even 4 gears. not try to immagine the stress you put on the drivetrain by using it. Ferray, lambos and so on does not have the switch because of this. |
01-07-2020, 01:35 PM | #152 |
Rep 251
here is a video that explains it better than 1000 words
mikeyymonster526.00 |
01-07-2020, 01:58 PM | #153 |
Rep 8,970
I never use it out of mechanical sympathy.
Just drop the gears manually prior to accelerating, just like you would in a manual. It's quicker this way for overtaking as you are in the gear you want BEFORE you gas it rather than waiting for kickdown AFTER you press the gas. ...and its kinder on the car.. |
01-07-2020, 02:03 PM | #154 | |
Rep 7,594
Drives: '19 M2C
www.ReTuneTheDeTune.com
