10-18-2019, 10:27 PM | #1 |
Rep 328
Downpipe with stock exhaust?
My M2 is completely stock right now and I am considering a downpipe. I do not have the M Performance exhaust. Since it is my daily, what I am looking for is no drone whatsoever. What are your suggestions?
And this is a general question: If the downpipe triggers a CEL, aside from the yellow light on the dash, does it affect the engine in any way? Like richer air-fuel ratio? |
10-19-2019, 03:36 PM | #2 | |
Rep 1,899
10-19-2019, 06:20 PM | #3 | |
6634
Rep 4,145
Drives: '18 M2 6MT
If you get any down-pipe other than the FabSpeed then you will get a CEL, and it will in no way hurt anything, or cause any issues, it's just that the dealer isn't going to like it. And even if you get a FabSpeed down-pipe there is no guarantee you won't get a CEL. They will lie to you and tell you that it won't happen if you have a correct install, and they are 100% no-CEL, but it's not true. And remember, even without a tune you will still get some hp/tq from a down-pipe, even if it's catted. And lastly, don't pay big bucks to some specialist to put the down-pipe on, it's literally a joke, so go the cheapest route there. I'll bet your local Jiffy Lube could do it. |
MetalMK228.50 JackyStuntin154.50 |
10-19-2019, 09:45 PM | #4 | |
Rep 328
10-19-2019, 10:58 PM | #5 | |
Rep 1,466
With a downpipe the whole exhaust becomes louder, including the drone. If you're OK with the drone now, you'll be OK with it after, but do keep in mind that everything will be louder.
2018 ///M2 LCI, LBB, 6MT...
10-20-2019, 07:14 AM | #6 | |
6634
Rep 4,145
Drives: '18 M2 6MT
An exhaust with no drone is possible, but it's a bit like cutting off your nose to spite you face because it'll be louder than the drone was at all times. |
10-20-2019, 10:12 AM | #7 |
Rep 19
I run a vibrant J style o2 spacer on my catless for 2 years now and no check engine light.
BoltacoreMD3.00 |
10-21-2019, 12:35 AM | #9 | |||
Rep 328
10-21-2019, 11:20 AM | #11 |
24174
Rep 190,750
Car will run as normal even with the CEL.
If you are using a Jb4 or stock, get the Fabspeed downpipe for no CEL. If you are using bootmod3 or Active Autowerke flash tune, you can use any downpipe and you wont get a CEL
10-21-2019, 11:58 AM | #12 | |
Rep 328
10-21-2019, 03:47 PM | #13 |
Not Mids
64
Rep 85
I run a VRSF catless dp with the OEM exhaust and there is no drone whatsoever. Its a must have mod Imo, I do run a tune but I have a bunch of other mods. They make the O2 spacers and even offer them with the VRSF pipe to help avoid CEL. I also disabled my active noise in the cabin which makes the engine sound too loud
2013 135i N55 - FBO
SOLD 2020 X3 Competition - Alpine white, dp + stage 2 SOLD 2018 LBB M2 FBO, Pure Stage 2 turbo |
10-21-2019, 06:48 PM | #14 |
Rep 553
If you’re hearing a variance in Sport/sport+ compared to Comfort ( same rpm, assume stock tune) then ASD is active.
10-21-2019, 10:48 PM | #15 | |
Rep 328
10-21-2019, 10:49 PM | #16 |
Rep 328
10-22-2019, 07:52 AM | #17 | |
Rep 699
I used the ASD bypass cabling as opposed to coding but the results are the same. |
10-22-2019, 02:11 PM | #18 | |
Rep 340
10-22-2019, 04:48 PM | #19 |
Rep 328
10-23-2019, 10:49 AM | #22 |
Rep 328
