M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Trouble downshifting into 2nd
      06-11-2017, 07:37 PM   #1
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
During enthusiastic road driving, I sometimes have difficulty downshifting into 2nd gear. I fully depress the clutch, well below the ~60 mph redline, but can't engage 2nd gear. It does rev match as I barely enter 2nd's gate. The car has 4000 miles on the clock.
Again, this occurs only sometimes during aggressive driving. Thoughts?
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      06-11-2017, 09:28 PM   #2
six-n-twins53
Amateur Tattoo Artist
809
Drives: 2018 M3 zcp
No offense, but the most probable explanation is that you are either not pushing in the clutch all the way, or you are applying force in a direction other than left and rearward on the shifter.
No Boost4021.00
      06-12-2017, 03:12 AM   #3
No Boost
No Boost's Avatar
None taken but, I've certainly applied both of those obvious actions.
      06-12-2017, 06:49 AM   #4
six-n-twins53
809
Drives: 2018 M3 zcp
If you trust someone enough to let them drive it, see what they think. Otherwise take it to the dealership and let them check it out
      06-12-2017, 08:19 AM   #5
NOLAGUY
Drives: LBB M2
Do you have the BMS clutch stop installed? Maybe too thick?
No Boost4021.00
      06-12-2017, 09:36 AM   #6
No Boost
No Boost's Avatar
That crossed my mind but again, under normal driving, downshifting into 2nd is no problem.
      06-12-2017, 09:39 AM   #7
BruceM
Drives: '17 6MT MG M2,930,Jag XKR 5.0
I don't have this problem, but I do notice that this shift is the most difficult to time and smooth out of all the shifts in this car...
No Boost4021.00
      06-12-2017, 10:02 AM   #8
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Could it be the tune interfering with a car safety system? (100% unsubstantiated idea)
No Boost4021.00
      06-12-2017, 10:47 AM   #9
NOLAGUY
Drives: LBB M2
More guessing....but maybe during heavy driving everything is hot and your clearances shrink up a little. Maybe that's enough to make the BMS stop too much.....once again, just guessing.
It's at least an easy thing to change to see if it helps.
      11-19-2019, 06:13 AM   #10
No Boost
No Boost's Avatar
I discovered the problem. I'm a complete idiot...
I was pulling too far left to engage 2nd. Extreme left (and up) is the safety feature to engage reverse. This is my first manual BMW. All my others were 5MT where reverse was directly below 5th on the gate pattern.
