05-22-2023, 09:27 AM | #1 |
Rep 4,672
Initial impression of catless DP
I added the catless DPs this weekend. I used a set of quickjacks and did everything from below the car. This was difficult. The O2 sensor on the short downpipe is in a difficult to reach spot. If there is any chance the sensor is going to be tough to remove, I'd suggest using the posted method where you go through to top. Remove the charge pipes, and unplug the sensors. Honestly, if I did this again I think I would use that method. Working above the engine is much easier and forgiving than working below. Plenty of YouTube videos on removing the brace and chargepipes. I probably spent over an hour trying to get to, and loosen, that single sensor from below the car. I was quoted $600 to replace the pipes at a quality local shop. That was twice what I was willing to spend. After doing the work I can't say that it would be crazy to pay for it. Includes install, the gaskets, and guarantee. It took me 8hrs not knowing what the hell I was doing. An hour was spent just collecting tools, which required crawling out from under the car, fetching, and crawling back under. I didn't drop the midpipe, but I think it may have been quicker to drop it as well. All in all there are a couple of things like going in through the top of the car to avoid removing the O2 sensors while on the car and dropping the exhaust that seems like lots of extra effort, but probably save time and make the job less stressful overall. Knowing exactly what tools I need and following the regular instructions I could probably do it in 4hrs.
Remember to use copper anti seize. The silver stuff has a much lower temp rating. My DP to turbo gaskets still looked good, but I replaced them anyway. It looked like I could have reused my DP to midpipe gaskets. They still looked brand new. I replaced those too. Sound. Uh oh, what did I do? I wanted it louder and yep, it's louder. Normal operation is louder unless really low load on the engine. Depending on speed and gear you can have it near silent if you want. There is now a pronounced drone around 2800 rpm that was not there with stock DPs. I have to drive through my neighborhood in 2nd gear now. A slight change in driving style avoids it. No drone present at highway speeds. Under load it sounds amazing. Valves open is just bonkers loud. Super fun, but not neighborhood friendly. Overall when getting on the throttle it sounds really good. The only noise I don't like is if you quickly get out of throttle it can make a weird resonance sound. Tough to describe. Happens infrequently, but it's there. Not all sounds with the catless dp are pleasant. Exhaust smell doesn't bother me. Occasionally notice it. I drove with windows down this morning and got a whiff only once. Windows up there is nothing. Burbles. A lot more burbles. I'm not a burble fan and I quite like the CSs minimal burbles. Well, the new dps don't mute any of those. Lots of rumbling. Not bad, but sometimes I feel like it doesn't go with my gray hair.
05-22-2023, 09:49 AM | #2 |
4693
Rep 2,542
I try to stick with catted dps until the power level and/or usage dictates it. Like you said there is a lot of good with catless but for me the bad outweighs it unless it is a track car. I find catted is the sweet spot except for the cost bump.
I would recommend investing in a set of these - I sport them when I'm out in my straight piped M4... |
05-22-2023, 10:03 AM | #3 |
24198
Rep 190,807
Thank you for your review
The installation process certainly shouldn't take up to 8 hours. Given the appropriate tools and installation experience, it should only take a few hours. This is, of course, assuming you received a good downpipe.
05-22-2023, 10:10 AM | #4 | |
Rep 4,672
Oh, that little effing pin that holds the lower part of the long dp to the bracket. (With the wire washers) that SOB took me 1.5hrs to get on. I have a technique now though. Another suggestion is to do yourself a favor and get a creeper. This was very handy, buti should have followed it completely. https://f80.bimmerpost.com/forums/sh....php?t=1096302 |
05-22-2023, 10:17 AM | #5 | |
24198
Rep 190,807
05-22-2023, 10:20 PM | #6 |
Rep 4,672
Drove around more today. Loving this change. Had my 4yo laughing in the back seat. He likes the valves open. Equates the loud exhaust with speed. It's fun. Thank goodness it's a valved exhaust. No way in heck could I handle an open valved system like this waaaayyyy too much. Normal valve operation is plenty.. I'm certain I won't be using the valve controller as much to open the valves. I did an open valve cold start in the parking deck today and admittedly felt a little embarrassed. Valves open is straight up a**hole mode, but sometimes I'm feeling it. It's kinda therapeutic after a long day
(K)1278.00 |
05-22-2023, 11:17 PM | #7 |
Rep 837
I'm hesitant to do the downpipes because of exactly what you mentioned regarding rasp/drone. Many clips of downpiped cars evidences the rasp which I'm wary of.
I find the factory valve behavior to be pretty good also but if I could make changes to the factory valve operation I'd have it open from 1st-3rd instead of 1st and 2nd only and also on downshifts. Having the valve controller is still great though for the occasional "rowdy mode." |
05-23-2023, 05:45 AM | #8 | |
Rep 4,672
05-23-2023, 06:56 PM | #9 | |
Rep 164
05-24-2023, 12:20 PM | #10 |
Rep 837
I have the Akra evo system so I'd likely stick with the same branded downpipe if I were to continue down that rabbit hole. This is my "everyday" car so downpipes aren't high on the list, I'm not (currently) planning to pursue [too] much power or sound. I'm finding that even a minor, temporary drone/rasp would probably drive me nuts.
05-24-2023, 03:00 PM | #11 | |
Rep 4,672
05-25-2023, 12:20 PM | #12 |
Rep 4,672
Interesting finding. I thought the factory valve behavior was a function of comfort, sport, and sport+. Changing between those didn't really do anything. There was a big change between switching MDM on and off. That surprised me. The Akra valve controller seems to mimic the factory MDM off logic. MDM on seems to keep the valves open more below 3k rpm. Anyone else experience similar between MDM on/off?
06-11-2023, 04:09 AM | #14 |
Rep 4,672
Yep. I've got a full Akra system DP, mid, and backbox. Still loving it. The stock logic is now plenty loud. Occasionally I'll go full open, but it's kinda too much. It's loud. It doesn't sound too loud until you roll the windows down.
