04-29-2023, 06:15 PM | #1 |
Rep 327
feedback on a differential brace
I have a stock tune CS with Akrapovic exhaust and intake. I don’t plan on tuning, but I am looking to eliminate wheel hop upon take off.
https://www.rktunes.com/products/rk-...3-f87-m2-m3-m4 Who has one and does it eliminate wheel hop? Any drawbacks to it? I read that the F chassis only has one mount vs 2 on the E and G chassis. |
04-29-2023, 08:31 PM | #2 |
Rep 837
I think it's a worthwhile mod (it's on my to-do list) and I think you may want to consider the Powerflex bushing kit in addition to the differential bracket to help with the wheel hop also. I've been reading that the street bushings don't introduce NVH (or at least not a significant amount). I figured if you're going to do the bracket you might as well do the bushings too.
https://www.powerflexusa.com/shop/pr...ory=1779#attr= Edit: I'm seeing that RKTunes uses Powerflex bushings in their full kit too. You can't go wrong with any of these bracket kits as long as they're using the Powerflex bushings. It really comes down to your preference in color and which vender you want to support as the prices are similar. |
04-30-2023, 02:04 AM | #3 |
Rep 553
I have the Powerflex dual mount bracket + their purple rear mounts (x 2) & the purple front diff mounts (x 4). Got them fitted when the diff/sub-frame had to be lowered to replace leaking diff seal.
There is a climbing hairpin corner near home & every time I turned that corner the inside rear wheel would lift & cause terrible drivetrain backlash as the wheel would repeatedly lose/gain traction (fairly light acceleration). Since getting the Powerflex mounts the drivetrain backlash has gone, the inside wheel still loses traction but it's now smooth. I have 6MT and can't speak for the wheel hop guys get when doing DCT launches. The only negative is a diff whine when cruising at 100kp/h but I think that's more to do with the Powerflex purple mounts themselves and not the dual mount. You could go with the oem rubber mounts and most likely have no noise (I also had the oem oil filled rear mount which was updated to a solid rubber mount early 2018). |
(K)1278.00 |
04-30-2023, 07:39 AM | #5 | |
Rep 1,335
I have the oem front ones, and 2 oem rear ones (polyurethane), 0 noises. |
04-30-2023, 07:23 PM | #6 |
Rep 553
I didn't notice any change to shifting with the Powerflex diff setup, note I already had AS SSK 20% (+ Raceseng Circuit Sphere), clutch stop 2 shims, CDV delete & Rogue trans mounts (& more recently the Turner shift arm rear poly mount).
04-30-2023, 07:35 PM | #7 | |
Rep 553
What did change with the bracket/dual mounts is a 'smoother' drivetrain when the inside wheel was losing/regaining/losing/regaining..... traction. I can only assume with the oem single rear mount the diff was rotating under the changing load of losing/regaining traction & causing backlash (it was loud and didn't sound kind to the drivetrain). Still lose traction with the dual diff mounts but it's smoother & the horrible backlash is gone. |
chris7197334.00 |
05-02-2023, 06:35 PM | #8 |
Rep 327
Thank you for the feedback. I will probably just add another factory bushing if I do move forward with this.
My car is a 6 speed manual and I want to enjoy the car while minimizing mods. The couple sites that showed install instructions with detail pics made it seem more involved than installing an intake or exhaust. I like easily reversible mods should I ever choose to sell it. |
