09-24-2021, 03:31 AM | #23 | |
Rep 7,429
09-24-2021, 11:24 AM | #24 |
Rep 7
Great, thanks for the info!
09-24-2021, 01:14 PM | #25 |
Rep 7,429
10-01-2021, 05:18 PM | #26 |
Rep 7
Just as an update, I ordered Bosch ZR5TPP330A from FCP Euro, but received ZR5TPP330 (no A suffix). I tried searching for what the A suffix means, but couldn't find anything. There is a PDF on Bosch's site here: https://www.boschautoparts.com/en/au...gs?partId=8165 (titled Spark Plug Number System or Design Codes), but no indication of what that last 'A' might stand for. I'm assuming it is some sort of revision but based on the same design/specifications. I saw a previous comment where you mentioned a TSB about cracking and the only thing I could find was TSB SI B12 25 14, which defines switching from Bosch ZR5TPP339 to Bosch ZR5TPP330A to solve a cracked insulator issue.
I can search ZR5TPP330A images and see the 'A' stamped on the plug itself, but mine do not. The boxes also looked pretty old and beat up, which leads me to believe they were old stock. Another interesting point is the box is labeled with a 0.032" gap and I believe OE is 0.028". Anyway, I am returning them and I think I'm either going to order the genuine BMW replacements from FCP (because of their lifetime replacement program, I can spend the OEM money once and keep replacing them) or just order the ZR5TPP330A from somewhere else and see how they turn out. |
10-01-2021, 05:24 PM | #27 | |
Rep 7,429
Also the bosch plugs should be pregapped to 0.028" (but if this is not the case then I am mistaken) but if not then you will have to manually gap them down yourself.
10-01-2021, 05:39 PM | #28 | |
Rep 7,429
The part number on the box is different between the 330 version and 330A version.
10-01-2021, 06:32 PM | #29 | |
Rep 7
I've also realized that Bosch refers to their parts by the 4 digit number. When searching on their site for a 2017 M2, it comes back with 8165. This is the part number that is printed under 'ZR5TPP330' on the box that I received. It also mentions a 0.8 gap on the site, which I'm assuming is mm, which correlates to 0.032". So if I were to just use Bosch's recommended scheme, I'd think I'd need 8165 and never even know there was a 330 vs. 330A. |
10-01-2021, 07:02 PM | #30 |
Rep 7
Also, just wanted to mention that according to FCP Euro, BMW part number 12120039634, which is what is specified on the realoem diagram, is Bosch part number ZMR5TPP330, which we knew. However, on this site, is also mentions the gap to be 0.8mm/0.031".
I plan on checking the gap on the plugs that come out of the car, but I bought it used, so unless they're branded with the full OEM markings, I can't be sure they're correct. In the same line of thinking, I can't guarantee the FCP Euro specifications are exactly correct either, but it does seem as though 0.8mm is the stock gap from what I can tell. |
10-01-2021, 07:16 PM | #31 | |
Rep 7,429
8165 was listed so the 8165 number you mentioned is also the same as the 330a version. It does mention 330 as being the same but that is not the case with the update. Yeah 0.8 is the mm size, bmw doesn't mention stock gap sizes anywhere but from alot of looking I also came to several conclusions the stock gap was 0.7 mm or 0.028" and the bosch plugs were supposed to be pregapped to this size. However they might not be, or the knowledge that the stock gap size is 0.7 mm might be inaccurate. I have some old plugs at home I can check if I get some time.
10-01-2021, 08:30 PM | #32 | |
Rep 7
10-01-2021, 08:46 PM | #33 | |
Rep 7,429
But yeah you can email Bosch and ask that's always best. All I know is that BMWs tsb says the A version is updated due to the 330 having a cracked body.
05-18-2023, 02:25 AM | #36 |
Rep 15
