M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Manual Trans Gear Lever Vibration
      10-01-2020, 03:30 PM   #1
mrcheezle19
Drives: 21 M2C 6MT
Question for you guys. When accelerating in 4th gear the shift knob has a rather heavy vibration that the other gears do not. This is through most of the rev range 2000-5500. I am not resting my hand weight while driving on the shift knob but just a feeling I've noticed while changing through the gears. I know a slight vibration or feel is normal as it's a manual but I would say it's a 300% increase in tangible difference from all the other gears and 4th gear. Thanks for you time.
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT
Past: BMW e30 m52 turbo 628whp/558wtq
      10-02-2020, 11:14 AM   #2
nearwater4me
Drives: '22 G82 Base
Hmm, I’ve never noticed excessive vibration on the shifter.
I’ll pay close attention today when I drive my car tonight.
      10-04-2020, 06:45 AM   #3
Acetech
Acetech's Avatar
Drives: 03 M3. 98 M3. 11 1M
Is your shifter stock or have you installed any aftermarket parts?
      10-04-2020, 09:46 PM   #4
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Every manual car I have driven that isn't a cable shifted car has done this in 4th. I consider it normal
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
      10-04-2020, 11:43 PM   #5
mrcheezle19
Drives: 21 M2C 6MT
Stock shifter. I had an OG M2 and never noticed 4th gear having such a stand out difference from other gears.
      10-05-2020, 10:30 AM   #6
nearwater4me
I paid close attention to the shifter over the weekend, softly touching the knob in each gear.
4th didn’t seem to exhibit any more vibration than other gears.
All very slight vibration.
      10-06-2020, 12:38 AM   #7
mrcheezle19
Drives: 21 M2C 6MT
Thank you for the input. That slightly concerns me as mine is quite obvious. I’ll definitely mention it next time I’m at the dealer. Hopefully a few others can chime in.
      06-22-2021, 06:38 PM   #8
cyberkaa
:facepalm:
cyberkaa's Avatar
Drives: 2x 2003 332i, 2020 M2CS
My 2020 M2 CS has had the same 4th gear shift lever vibration you described from new. I thought it was strange because my 2019 M2C had nothing of the sort and I had them both side by side for several months. I haven't investigated it yet or notified BMW of the problem. Curious how common it is.
      06-22-2021, 08:18 PM   #9
stefan
stefan's Avatar
Drives: M2 Comp
You sure you don't feel it in your butt as well? Sounds like the diff issue.
///M Power
      06-23-2021, 03:04 PM   #10
nearwater4me
Interesting. But why only the 4th gear?
      06-23-2021, 06:08 PM   #11
stefan
stefan's Avatar
Drives: M2 Comp
likely low rpm, high speed, high boost. A quick search reveals this problem is somewhat less isolated than we thought.
///M Power
      06-23-2021, 11:54 PM   #12
chris719
Drives: '08 M Roadster
Never had it in my Z4M that I noticed, and that shifter is considerably less rubbery and isolated.
      06-26-2021, 11:32 AM   #13
mrcheezle19
Drives: 21 M2C 6MT
It's at any speed/RPM/throttle input/boost level. It does it maybe 8/10 times. The times it does not it is just like the other gears and there is no vibration in the gear lever. I've brought it up twice the BMW and they say it's normal, but they've noted it so in case it's a issue later they have a track record. I'd rather them not tear apart a transmission over a non drivability issue. I just don't want any issues if it requires a replacement down the road.
I don't notice any driving issues just more of an oddity. My 2017 didn't do this, but whatever.
      05-21-2023, 03:39 PM   #14
DadVibes
DadVibes's Avatar
1247
Drives: F87 M2 CS
Bumping this old thread as I’m experiencing the exact same thing and I’m at a bit of a loss.
I just traded my 14k mile 6MT M2C in for a 3k mile 6MT CS. After getting more time behind the wheel, I’m finding that 4th gear has a very notable increase in vibration feedback through the shifter than any other gear.
I don’t recall my M2C having this “issue”. However, it’s possible I just wasn’t being as hypersensitive to the shifting experience in that car. With my hand off the shifter, everything feels perfectly normal. No other vibrations and the car performs as expected. Just this weird extra vibration in 4th.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S
      05-22-2023, 12:11 PM   #15
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
I haven't noticed it if it is present in my car.
DadVibes1247.00
      05-22-2023, 01:33 PM   #16
(K)
(K)'s Avatar
1278
Drives: '21 M2C 6MT (R.I.P.)
Mine buzzes (buzzed) in 3rd and 4th during acceleration. I chalked it up to the SSK, 95a bushings, MP shift knob, and just general functions of the transmission. Have had similar experiences with my Infiniti (vibrations but no noise) and other RWD cars so I've come to accept it as normal as long it's not excessively rough.
DadVibes1247.00
      05-23-2023, 10:00 AM   #17
DadVibes
DadVibes's Avatar
1247
Drives: F87 M2 CS
Yeah, I do think the Autosolutions SSK is allowing more vibration to come through, compared to the mushy OEM setup. But it's still strange to me that it's only in 4th. And even with the same SSK installed on my Comp, I never noticed it.
That said, it does seem to be intermittent and during my last two drives, I felt little to no additional 4th gear vibration. I'm just going to chalk up to normal drivetrain behavior, exaggerated by the stiffer bushings/shifter.
      06-03-2023, 10:48 AM   #18
mrcheezle19
Drives: 21 M2C 6MT
Im the originator of this thread I still have the car now sitting at 15k miles. Issue is still present and hasn’t gotten worse or better. Every time I come in for service I make sure my SA notes it on the RO so there is a record of it on going. I had the shop foreman take it for a drive with me and while he noticed the issue he chalked it up to normal. I’m kind of at a cross roads because while I could probably push for a new trans, do I really want that big of a job performed for a minor issue? I figure as I get closer to the end of my warranty ill decide my future with the car and if I’ll really push for a replacement or not.
      06-09-2023, 02:02 PM   #19
NCM2C
Drives: BMW 2020 M2Comp
Any update on this? I noticed a noise from the car + constant vibration/wobble in the shifter - most noticeable at low speeds. It is not RPM pending - it's speed / driveshaft spin pending.
