BMW M2 Forum > BMW M2 Competition Model > What did you do to your M2C today?
      04-08-2020, 10:19 PM   #1761
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Originally Posted by Quicksilver_M2C View Post
Sounds like a good idea but won't that stuff get flung around when the rotors get hot?
How's it going to fling? The rotor hat sits flush with the back of the wheel-- nowhere for it to go.
      04-09-2020, 09:43 AM   #1762
M2Cmtl
Drives: 21 Q7 & 22 4XE
Why the hood sound insulating pad?
2020 M2C 24.04.2020 delivery - Sold 24.08.22
      04-09-2020, 09:48 AM   #1763
flybigjet
flybigjet's Avatar
Because I'd like the car to be a bit quieter.
I've also got the trunk and side sound insulating panels as well as the big metal parts that go over the open holes above the rear wheels, but that's an entirely different project.
      04-09-2020, 10:49 AM   #1764
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
Fly - I had seen your post where you had listed the parts, which was very useful. However, I couldn't tell which parts are the ones that go in between the doors and the front fenders. I think its like a strip that goes in the door hinge area. Others have said that was the most effective in sound reduction? Could you post those part numbers along with the hood insulation parts? Did you notice any noise reduction with the hood insulation?
Thanks
      04-09-2020, 11:33 AM   #1765
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
Thanks
Fender to Body Seal - Left
51487300693
Fender to Body Seal - Right
51487300694
Hood Insulation
51487221993
Clips x18
51489119216
      04-09-2020, 11:40 AM   #1766
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
51487300693
51487300694
Hood Insulation
51487221993
Clips x18
51489119216
Thank you. Have you installed these, and whats your take on the reduction achieved? Also do the fender body seals have tape on them to adhere to the panel?
      04-09-2020, 12:30 PM   #1767
flybigjet
flybigjet's Avatar
Thanks
M2C soundproofing parts
- Door seal, left (51487300693)
- Door seal, right (51487300694)
- Hood insulation pad (51487221993)
- clips for above (51489119216 x18)
- Side cover, left (41007294289)
- Side cover, right (41007294290)
- Trunk insulation, left (51487296055)
- Trunk insulation, right (51487296056)
- clips for both above (51471911992 x12)
- Wheel housing, left rear (51487334357)
- Wheel housing, right rear (51487334358)
- clips for both above (51489119216 x12)
      04-09-2020, 12:32 PM   #1768
2020M2Competition
429
Drives: Yes
So far, I've only installed the fender seals (although I have all the other insulation bits to try out at some point as well)
They do provide a slight reduction in noise (primarily from the tires/road)
It's not a huge difference but definitely noticeable
They do not have any tape on them
They basically get wedged between the fender and the body
If installed properly they do not require any tape or adhesive
The only potential drawback I see to installing them (especially since I track my car) is that they may trap some heat in the engine compartment (which is also why I haven't yet installed the hood insulation)
      04-09-2020, 01:16 PM   #1769
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Thanks, what change did you notice with the hood insulation?
      04-09-2020, 01:17 PM   #1770
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Very helpful. Thanks!
      04-09-2020, 01:18 PM   #1771
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
I don't see how the under hood sound insulation traps any meaningful heat, when it comes standard on all M5s and above.
I honesty believe it was omitted on the M2 to give it a sportier sound, i.e. a mixture of injector ticking and intake charge noise...
Also, you guys with M2Cs, keep in mind that you're using the hood insulation part from a F22 M235i, which has a slightly different shaped hood than the Competition model, since it has to accommodate the top mounted intercooler, the M235i/M2 doesn't.
Not sure if the hood insulation from the M235i would fit precisely on Competition, due to this fact.
JustChris17481.50
      04-09-2020, 04:34 PM   #1772
Quicksilver_M2C
Go for it now. The future is promised to no one
Quicksilver_M2C's Avatar
Drives: 2020 M2C
I guess I'm not understanding what you meant. I understood you were going to spray Cosmoline RP-342 on the inside of the rotors (vents)
      04-09-2020, 05:52 PM   #1773
2020M2Competition
429
Drives: Yes
Well, the hood insulation is pretty thick and is close to the equivalent of putting a blanket on top of your engine
Nevertheless, like you said, it probably won't make a significant difference
      04-09-2020, 10:16 PM   #1774
flybigjet
flybigjet's Avatar
In the center of the rotor hat-- where the center nut and cotter pin are.
      04-10-2020, 04:21 AM   #1775
ashtaron14
ashtaron14's Avatar
Hong Kong
1123
Drives: G80 M3
Installed E9x Clutch Slave.
Now it's much easier to locate the clutch point, and yes the pedal effort is lighter (Stock E9x). Along with the ASD delete (fake engine noise removal), the AutoSolutions shifter with 80A PU bushings, my car has regained all the non-modern car noises and gear whine
m20e30871143.00
///M Houbi1653.00
      04-10-2020, 06:58 AM   #1776
Quicksilver_M2C
Drives: 2020 M2C
gotcha, I cleaned mine out and put some rust inhibitor on it as well
      04-10-2020, 11:56 AM   #1777
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Had to take my M2 for a nice drive. The battery was so low that the alarm flasher stopped working. Nice that it started up on the first try though. It is hard on these cars sitting around when they are use to being driven daily.
F80_Katz762.50
      04-10-2020, 06:57 PM   #1778
F80_Katz
F80_Katz
763
Drives: 2020 M2 Competition
2008 Bmw E90 M3  [0.00]
Took her in for the second service, oil change and check over. Also had some interior rattles resolved and the brake rotors warrantied.
Rattles were coming from the two speaker covers behind the rear headrests. Removed the covers and added some felt tape around the edges. Silence👌🏻
Poochie9103.00
DanG10550.50
      04-10-2020, 08:02 PM   #1779
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
What do you mean you had brake rotors warrantied?
      04-10-2020, 08:15 PM   #1780
F80_Katz
F80_Katz
763
*Replaced under warranty* they were shot and it was shaking like hell when braking. Garbage iron rotors.
      04-10-2020, 11:38 PM   #1781
Cannondale900
Drives: '20 M2C, '10 535ixT, '91 M5
2023 X5 45e  [0.00]
2015 LR4 HSE Lux + HD  [0.00]
1965 Shelby Cobra 4 ...  [0.00]
2020 M2C  [0.00]
1991 M5  [0.00]
2010 535ixT  [0.00]
I stole her shoes to satisfy a curiosity
Appreciate 4
ki__409.00
Supernaut391.00
ROASTM163.50
      04-11-2020, 08:06 AM   #1782
cb804
cb804's Avatar
2350
Drives: 340 xDrive, M2C
That looks good!!!
