11-17-2019, 12:15 AM | #1 |
Rep 594
Another wheel hop thread...
I'm losing my mind over this...
Some people report no wheel hop, I get it for days 1st and 2nd gear depending on conditions. 6 speed manual, stock Pilot SS tires I've tried everything from 38 psi down to 32 psi. It's just bad. Has anyone found a solution. I can't run a small wheel due to the rear brake clearance. I've seen some people mention the diff mounts. I'd love to get this sorted once and for all. |
11-17-2019, 06:02 AM | #3 |
Rep 594
11-17-2019, 01:13 PM | #4 |
844
Rep 1,962
Well, the cause is either a problem with the transmission (or, maybe the rear suspension), or a loose nut behind the wheel.
If you're experiencing this effect anywhere other than at the drag strip, best take it to BMW and get it checked. My clutch (6mt) was sticking leading to poor shifting (the dealership diagnosed this - I just mentioned on booking in that it was reluctant to go into gear), so it's possible. Last edited by M Fifty; 11-17-2019 at 02:38 PM.. Reason: grammar |
11-17-2019, 08:31 PM | #5 | |
Rep 566
If it really is wheel hop take the car to the service and have the rear axle control arms bushings checked and replaced if necessary first. Also, check the differential mounts, if the above fails. True wheel hop is weak bushings vs grippy tires which results dynamic alignment changes and loss&gain of traction cycles that feel like wheels skipping and hopping, gets worse the grippier the tires, goes away with crappy (e.g., winter) tires. ps: might want to check the alignment, too. certainly, get alignment done if bushings are replaced. Last edited by x233; 11-18-2019 at 12:03 PM.. |
11-17-2019, 10:39 PM | #6 |
Rep 594
I mean it's been doing it since my 1200 break in right when I was able to gun it, just hops and hops. I'm in florida. not really such a thing as a cold day until just about now.
I keep dropping my PSI I think an adjusted alignment will help and be cheap. Luckily I work at the dealer. I don't want to bring it in unless I KNOW there's a problem. |
11-18-2019, 06:45 AM | #7 |
6634
Rep 4,145
Drives: '18 M2 6MT
I bought my car used with 9400 miles on it, but the dealer had replaced the tires (stock Conti's) and had the alignment checked before I picked it up, so all that was good. At first the car would hop real bad on uneven surfaces, or if the ground was wet, or just pulling out of the car wash. Now, about 1500 miles later (almost all highway), it breaks away very smoothly. I think it's a bit of tire wear, and the colder temps, but others report it's worse when cold.
All I know is that I'm glad mine *seems* to be gone. |
