11-16-2019, 01:40 PM | #1 |
Rep 14
Help, coolant water pump, problem
Hi guys I’ve searched high and low, but can’t find anything on our cars, I via problem with my water pump for coolant system, I’m trying to find a fuse or relay that sends power to the pump, I no my pump is good, I had a damaged it connector for the pump, while replacing the connector one of the ends touched metal part of engine somewhere, I heard a click to the right of the car, but unable to find a fuse that has blown , any help would be much appreciated, thanks
11-18-2019, 06:21 AM | #2 |
Rep 1,658
Drives: 2022 WRX World Rally Blue
You have an owner's manual in your Idrive as well as a paper one. If you don't you can download it.
To save you the trouble of looking that up there is a fuse box in the trunk by the battery and one under the hood. Look for a black triangular plastic piece on the left side as you're looking at the car from the front.
Rick
11-18-2019, 10:44 AM | #3 |
The deuce gets loose
290
Rep 499
If you want to make sure your pump works, look up how to bleed the system. I think you turn the ignition on and then hold the gas to the floor until the waterpump starts the bleed procedure. Engine off of course.
