M2 Technical Topics > Suspension | Brakes | Chassis > Coilover Covers for winter?
      11-01-2019, 09:56 AM   #1
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Hey, I tried searching about this on the F87 forums, as well as across all of bimmerpost, and the only thing I found was this:
https://www.e90post.com/forums/showthread.php?t=1156072
Does anyone here have coilovers installed and drive their cars in the winter time with snowy conditions with potential for salt sprinkled on the roads? I installed a set of Ohlins this summer and this will be the first year they will see winter, and I want to prevent them from seizing.
There seems to be a bit of a debate as to whether "coilover covers" are actually better or worse for your coilovers, as with them more water/elements could be trapped under the cover, potentially making matters worse. But I don't have any first hand experience and it seems that there really isn't that much info out there.
Am I overthinking this, and perhaps just need to apply some anti-seize on the threads and call it a day?
Here's an example of a cover made of neoprene:
https://www.ebay.ca/itm/Neoprene-Coi...5dl2-r&vxp=mtr
      11-01-2019, 10:12 AM   #2
gphung
194
2018 BMW M2  [0.00]
Someone who made their own for their subie. Fronts didn't have covers on, rears did. These are made of a polyurethane coated nylon material.
      11-01-2019, 02:22 PM   #3
M Fifty
844
Drives: M2 & 330CI
It depends on what the damper bodies are made from. The MPS are stainless, with a plastic spring collar on the front - so a pressure washer will clean them up after a winter on the car.
The rears on the MPS aren't really coilovers - the spring is still separate - with the spring adjusters being well out of the way up against the chassis.
The Koni's I had on a previous car seized solid however.
For some bizarre reason the damping adjusters on the bottom of front MPS are made of aluminium though - which will electrolytically corrode in the presence of stainless steel...
      12-10-2021, 05:36 PM   #4
SteB
www.CoiloverCovers.co.uk
You can get really good quality and very reasonably priced British made coilover covers from www.CoiloverCovers.com I've personally used them myself and they work great. iirc worldwide shipping is only £6.99 (Around $10 US)
      12-13-2021, 03:31 PM   #5
LLB-M2
Germany
22
Drives: BMW M2 (N55)
I dont believe that the covers will protect them well in a daily driver.
Its never 100% wateeproof. Saltwater will get into it and cant find it way out. So you have a fine salty biosphere.
I protect my coilovers with a wax for trucks and agricultur machinery:
https://www.korrosionsschutz-depot.d...rmdose-1-liter
Okay, my coilovers wont see any salt, but i also use it in our daily drivers to protect metal brake tubes, suspension and the body from rust. And its works very good.
gphung193.50
Tags
coilover, cover, salt, snow, winter
