M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Anyone running 255/35R19 on their M2C’s front?
      11-01-2019, 08:10 AM   #1
Kkkattt
Drives: M2C
Hi everyone,
I am looking to get a set of winter tires for my M2C. Thinking of a square setup of 255/35R19 on 9.5 x 19 rims. I think the general consensus is that the front would be tight but still no rubbing. If anyone with 255 on the front can chime in, it would be appreciated. Thanks!
Kat
      11-01-2019, 08:35 AM   #2
Insane_Dawe
Drives: 18 White ZCP M3
Similar but not quite the same, just put on 255/40/18 winter tires on a set of 513m (9x18 ET29) no rubbing but haven't been driving aggressively.
Sadly, the tires do rub on suspension and are very close to fender at steering full lock.
      11-02-2019, 07:03 PM   #3
Neckbeardz
Drives: M2 Comp
I just put some 255/35/19s on the front and rear for winter.
They run fine but I hear a tiny bit of rubbing when I'm turning into a driveway with a steep angle. I only just got them though so I will need to do more testing.
      11-02-2019, 07:29 PM   #4
Caduceus
342
Drives: 2008 135 (sold), 2017 M2
Unless there's something different about the M2C vs the OG M2 in this regard, 255/35/19 is probably the most common, non-OEM sizing people chose to fit to the front wheels.
It fits fine. No rubbing, even if conservatively lowered with coilovers or shorter springs.
If the story is different on the M2C, I'll stand corrected.
      11-03-2019, 08:17 AM   #5
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Originally Posted by Kkkattt View Post
Hi everyone,
Kat
From the research I've been doing 19x9.5 front may rub depending on the offset. The set I was looking at was a 22mm offset and the tirerack web site says fender modifications may be necessary. Someone else commented on my original post, and said 19x9.5 does work with a 28mm offset.
Right now I'm leaning towards just going with the 19x9 rims through BMW but with 245/3519 square set-up. Waiting on pricing there.
      11-06-2019, 07:53 AM   #6
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Originally Posted by GodfatherNiko View Post
I am, 255/35/19 on OEM 641M wheels all around. No rubbing, no issues, and car looks great.
Looks good but what size are the rims? 19x9 front is fine, the issue from my research is with 19x9.5 front and the correct offset.
      11-06-2019, 07:58 AM   #7
JonD
Drives: 1 Series Coupe, M Sport
19x8.5, 19x9 they 641m’s OEM for the M2 with 2NH albeit I think BMW recomend 235 35 19 tyres
      11-06-2019, 09:56 AM   #8
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
Thanks, I ended up going with these as well for my Winter set-up. There is also a BMW rebate out there on Winters. I got another $70 off with that
      11-08-2019, 10:56 AM   #9
Neckbeardz
Drives: M2 Comp
The story is different on the M2C. I can confirm that as an owner of an M2C with that size tire on my car.
      11-13-2019, 12:35 AM   #10
Kkkattt
Drives: M2C
Thanks guys. The rims I was looking at were superspeed RF05 19*9.5 +25 offset with 255 35 19 Alpin pa4. Price is decent $3300CAD but also don’t want to have rubbing issue. 641M set from the dealer run $4200CAD. Running out of idea. Search will go on.
      11-13-2019, 01:44 PM   #11
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
Curious as well. Looking at a used set of winters in 255/40 19. I only have staggered wheels currently the stock 788M. I was planning on running these square tires on the car for the winter.
My summer setup is 255/35 front and 275/35 rear with no rubbing.
Two concerns I have are increase in profile and minor stretch of 255 tire on 10" diameter wheel.
Thoughts from anyone?
      11-13-2019, 02:28 PM   #12
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Man, $3,214 is pretty rough, but that does look fantastic.
      11-14-2019, 03:51 AM   #13
Ollie RS
Ollie RS's Avatar
Poland
42
Drives: BMW M2 Competition
255/35/R19 all round on the stock wheels with winter tires should be fine right?
      11-14-2019, 07:36 AM   #14
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
The issue from my research is the size of the front rims. If you stay with the stock ones you will be fine with the 19x9 fronts.
I ended up getting the BMW winter set through my dealer (19x8.5 front, 19x9 rear 235R35/19 square set-up). He worked with me a bit, so I got them for cost plus $200, just over $3000. There is a BMW rebate out there right now for Winter sets as well, so I will get another $70 back from that.
I had priced a square set-up through Tire Rack but those were 19x9.5 front (245R35/19 square set-up) and there was a note on rubbing. That set was $2700.
I bit the bullet on this, but there isn't a ton of options out there for M2C's unfortunately
      11-14-2019, 08:15 AM   #15
Ollie RS
Ollie RS's Avatar
Poland
42
Thanks a lot, i think i will go with 255/35/19 square setup Alpin PA4 with stock rims. I plan on getting a different set of rims for the summer so i will use the stock rims for my winter setup
