10-25-2019, 08:07 PM | #23 |
Rep 1,644
I doubt BMW manufactures any single component in the motor itself that they assemble in their factories. Bearing tolerances are so tight in motors today there's not much room for error. This was likely a QC issue at the bearing manf. they didn't catch.
10-25-2019, 08:41 PM | #25 |
Rep 2,310
Drives: 9Y0 Cayenne S
Unlikely BMW manufacturers the bearings themselves. The thin "shell" bearings.
Engine block, bearing caps and crankshaft are often machined in the engine assembly plant. I know with 100% certainty that some automakers do this, not sure about BMW. This means the engine is in fact "manufactured" or "produced" or "made" in the engine assembly factory, by virtue of the boring and grinding (metal removing or "machining") operations on site. Bearing shells are not machined during assembly. For engines that come from their own engine factories, BMW is responsible for the complete engine design and manufacture, and specification of all subcomponents, such as bearing shells. |
Digital_83262.00 |
10-25-2019, 09:00 PM | #26 |
Rep 6,218
Nothing new lol
10-25-2019, 09:34 PM | #27 |
Rep 1,136
Bearing Motoren Werke!
10-26-2019, 01:28 AM | #28 |
Rep 1,219
Bummer. I would not be happy if my new car had to have an engine replaced by a dealer. Nothing is ever as good as factory fresh.
Pyrat 21417.50 Digital_83262.00 |
10-26-2019, 01:46 AM | #29 |
Rep 500
Drives: BMW 330e F30 M-sport
Wonder why only G and not F, I was under the impression it was still the same generation B48 in the G-cars. (?)
EDIT: I see it says B48D and B48C, there's been a technical update then I guess. Did they switch out that part, and end up making it worse than the original one?
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
10-26-2019, 09:10 AM | #32 | |
3570
Rep 10,351
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-26-2019, 10:41 AM | #34 |
Rep 2,539
What build dates/VINs are actually affected? That's the key guys.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
bryanyoung0.00 |
10-26-2019, 10:55 AM | #35 | |
Rep 2,539
Why all this madness and no a single credible source posting an affected VIN/Build date range?
10-26-2019, 12:58 PM | #36 | ||
Rep 831
It primarily refers to a delivery stop of not yet delivered cars. Delivered cars are to be called in for service. So, I presume you will get contacted if your car has already been delivered and is impacted. But I agree, unless there is a documented case or clarity how many cars might be impacted, no need to get nervous.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
clee1982797.50 |
10-26-2019, 06:29 PM | #38 | |||
Rep 2,539
10-26-2019, 06:54 PM | #39 |
Rep 4,659
Drives: BMW
Doesn't seem like it's a huge issue in terms of number of VIN's affected. Recall/stop delivery was initiated some time at the beginning of October and at that time, only 23 Canadian G20 VIN's were affected in all of Canada which is relative low considering the number of G20's that have been sold and are currently available in stock.
clee1982797.50 530iDriver1707.50 |
10-26-2019, 07:30 PM | #40 |
Rep 10
Here is more official info for you guys.
PDF's attached for mobile viewers who can't see attachments
4
10-26-2019, 07:43 PM | #41 | |
Rep 1,386
Korvo368.00 |
10-27-2019, 02:37 AM | #42 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Did a quick search and didn’t see anything that the warranty has been extended. Will talk to my local dealers to verify this.
10-27-2019, 07:34 AM | #43 |
Rep 6
