M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > ultimate clutch pedal install help
      10-05-2023, 03:21 PM   #1
neonbrown
neonbrown's Avatar
Uninstalled most of the stock set up but ran into an issue where there is electronics blocking the clearance for the actual pedal to be removed.
Was wondering if anyone can chime in on how to navigate this properly without breaking anything.
      10-05-2023, 10:22 PM   #2
neonbrown
neonbrown's Avatar
did some research, found out its rear camera control module. was able to locate one of the bolts holding it in, but cant really figure out the other one.
would like to remove it to add the clearance i need to install the new pedal easily, so if anyone can chime in if they know how to remove it safely that would be much appreciated
      10-05-2023, 10:43 PM   #3
(K)
(K)'s Avatar
1278
Drives: '21 M2C 6MT (R.I.P.)
I had mine installed along with the SSK and new slave cylinder so I can't offer any first hand insight. However, hopefully these two threads can help you out:
https://www.2addicts.com/forums/show....php?t=1305692
https://www.2addicts.com/forums/show....php?t=1558148
neonbrown274.50
      10-06-2023, 01:50 AM   #4
neonbrown
neonbrown's Avatar
definitely had the information i needed, will try to tackle this project in the AM
(K)1278.00
      10-06-2023, 09:00 PM   #5
neonbrown
neonbrown's Avatar
I was able to complete it, it was actually fairly easy i just didn't know how to remove that bracket for the rear camera module.
The easy way to do this is to remove the module by unplugging the cables, and then you need to unclip the bracket from underneath (another post said you had to use a 90 degree pick tool, i got it done easily with a small flat head). You'll only be able to unclip the bracket this way.
(K)1278.00
      10-06-2023, 09:36 PM   #6
(K)
(K)'s Avatar
1278
Good tips for those looking to DIY this mod in the future!
neonbrown274.50
