07-13-2021, 08:38 PM | #202 |
Rep 185
Drives: 2020 M2 Comp.
Just received my set. Lightning fast shipping & excellent customer service!
Thanks HP Autosport! |
07-14-2021, 06:41 PM | #203 |
3847
Rep 54,376
Drives: F80 M3
PM for best prices or take a pair of springs at no charge at MSRP!
11-04-2021, 12:49 PM | #214 |
3847
Rep 54,376
Drives: F80 M3
Since Ohlins USA is no longer making spring substitutes, we are offering one free pair of Swift springs at the rate of your choice. Second pair at 20% off of retail. Free shipping to the US48!
12-23-2021, 08:46 PM | #220 |
3847
Rep 54,376
Drives: F80 M3
This is the latest step in the Öhlins Racing automotive philosophy for your F87 M2
– Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrifi cing comfort in your day-to-day transports. The time of compromises is over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. FEATURES www.roadandtrackbyohlins.com General Front Rear > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year limited warranty > McPherson strut > Single bleed adjuster > Spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 90 Nmm standard(tentative user select rates 80-90 N/mm) > Dustcovers > Use with original top mounts > Conventional shock absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 190 standard(optional 160 or 180 rates) > Dustcovers > Use with original top mounts Front rates in just about any rates or your choice and rear rates in 100, 110, 120 and 190n/mm BMS MR40/BMS MR40S1 |
