11-12-2023, 07:24 AM | #1 |
Rep 4
s55 engine weird noise
Anyone simmilar problem? Please help
M2C 2020 36000Km https://vimeo.com/883704089 https://vimeo.com/883703852 |
11-12-2023, 08:53 AM | #3 | |
Rep 1,614
I need to look at mine today, making a weird noise too but only can hear it when I rev the car over 3k, that said have not heard it with the hood open which I will do today. I would see if car is throwing any codes too just to see but prob not. |
11-12-2023, 10:34 AM | #4 | |
Rep 4
MooMooM21843.50 |
11-12-2023, 10:41 AM | #5 | |
Rep 4
https://vimeo.com/883737186 |
11-12-2023, 02:02 PM | #7 |
Rep 1,614
yeah mine sounds just like that when its cold but then when warms up and I rev it it gets even more pitchier, maybe its in even worst shape. I just took a video.
It seems like its coming from the alternator so I will probably replace that pulley first. This is what mine sounds like, similar I feel like https://www.youtube.com/shorts/oogJiSa5hSA |
11-12-2023, 02:38 PM | #9 | |
Rep 1,614
However if you are into doing it I have compiled a bunch of videos and instructions from the forum. This video shows how to remove the belt (without removing the fan, seems to be doable but definitely tight in there) Then this video is to replace the alternator tensioner Also a LOT of great info here for idler pulleys and just general on how to do all this https://f80.bimmerpost.com/forums/sh....php?t=1833401 Also a link there that shows how to remove fan if you want to go through the extra work, seems like a lot more work but then you have space to easily do the other stuff. Not sure what I will decide to do, maybe try without removing the fan but we will see. Annoying that this is happening on pretty low mile cars but hey, not the end of the world. |
11-12-2023, 08:28 PM | #10 |
Rep 28
i recently had to replace the idler and the crankshaft balancer on mine after ~30,000km....
idler was noisey/bouncy, and, two of the retaining bolts for the balancer had snapped combined it sounded quite a bit like engine knock on start. |
11-13-2023, 07:40 AM | #11 |
Rep 2,882
Something like this can be a real useful tool to find where a noise is coming from - just be careful around the fast moving bits.
https://www.amazon.com/Lisle-52500-M...541218484&th=1 |
MooMooM21843.50 |
11-13-2023, 07:47 AM | #12 | |
Rep 1,614
Are you google ads? I just ordered one this weekend |
11-13-2023, 09:46 AM | #13 |
Rep 2,882
https://www.amazon.com/Lisle-52500-M...541218484&th=1 I'm not a google bot, just doing my Mr. Magoo 'double tap' with forum comments today. Last edited by Maynard; 11-13-2023 at 12:08 PM.. |
MooMooM21843.50 |
01-01-2024, 03:42 PM | #14 |
Rep 3
Hey guys, looks that i had the same noises as you in my M2C(of 2020). In my case the noises appears at the same kilometers as you, and i take it to the mechanic to fix it, they replace the belt and the tensor belt. After 20k kilometers, i had the same noises so i take the car back to the mechanic again (but another) they did the same (last time was in november 2022). Actually (in november 2023) the noises have appeared again, idfk what to do, so if you have other way to fix it let me know pls.
01-01-2024, 05:42 PM | #15 | |
Rep 1,614
I had a similar issue that I just fixed (another thread on this page I just updated) my noise was similar to this but a bit quieter however when reving it would get as loud or louder than this. I tracked it down to a idler pulley, the bearings were a bit gritty maybe so although still spun fine it was making noise. Its strange that your mech replaced a bunch of stuff and car was fine for 20k and now its back, this could be a different issue such as before it was the belt or 1 of the idler pulleys so he replaced that and now its a different idler pulley or the tensioner pulley. Not sure if he replaced everything while he was replacing the belt or if he just did the belts. Find out what exactly was replaced, if it was everything then I will be curious because 20km is not that much but it would not be impossible for a bearing to go bad in that time (very unlikely though). |
01-01-2024, 05:44 PM | #16 |
Rep 1,614
I never updated here, took me a while to get to this lol, shows how little I use the car. But just got done replacing the idler pulley and seems like it was the problem (short ride and noise is gone). Did you get yours figured out?
01-02-2024, 02:29 AM | #17 | |
Rep 3
In my opinion (im not a mech) the issue could be caused by a pulley that after x kilometers do the belt tensioner or the idle fails. I will be updating this, thank you. |
01-02-2024, 06:35 AM | #18 |
Rep 1,614
Just seems strange that a pulley would fail again so quickly after only 20km so yeah let us know cuz like i said there are 2 idlers for example and he might have just replaced 1 and now the other is on the fritz.
01-02-2024, 07:56 AM | #19 |
Rep 3
