04-07-2020, 06:56 AM | #1 |
Rep 65
Feels Slower After Intake Install
Hey everyone, I posted this in a preexisting Intake thread also, but wanted to run it up the ladder a little bit.
*Disclaimer: I wasn't expecting the car to feel faster with an intake, I just wanted turbo noise . Intake system came today. Install was pretty simple, except when you drop a socket head down to the floor pan, finally get it out, and 10 minutes later drop a bolt down there, and have to fish it out too. Took it on a spin around the block real quick and the turbos sound great, can really hear them spool. As an added bonus it even adds a little BOV woosh also. So here's the issue. I don't feel like it's boosting as strong as it was. Maybe I'm just getting used to it or maybe...maybe it's something I did. I had a difficult time tightening down the O clamps around the silicon hose on the turbo inlet. I've already checked to make sure the hose didn't come off, and she's still on there. My question is, if those O clamps aren't significantly tightened could I be losing boost around the silicone hose? Would it throw a code if there was a "boost leak" of sorts? Don't get me wrong it's still pulling pretty dang good, but it just feels a tad bit off. Any advice is appreciated. Thanks everyone! |
04-07-2020, 07:12 AM | #2 |
Rep 3,069
Anyone who has done this on any car will always remove it. There is usually a brief period of placebo. Followed by realisation. Then removal. I may have been guilty of this in a past life
04-07-2020, 07:26 AM | #3 | |
Rep 744
You could have a small air leak which means that unmetered air is entering the turbo post the air flow meter. The engine would then be running lean and lose power as it thinks it getting X air but really its X +% and the fuel is only for X air. You could have fed up the air flow meter as some oiled filters are known to do, although this seems to be less common nowadays. As Davil said hot air intakes are not worth the cash. The stock system flows well enough for 800WHP according to a reputable S55 tuner near me. If you want more noise and have a stock US spec car, then remove the charcoal filters. EDIT: you can check if you have an air leak by idling the car and spraying carb cleaner/WD40/break cleaner near the turbo connections. If the revs pick up then you have a leak.
tom @ eas8112.50 |
04-07-2020, 07:30 AM | #4 | ||
Rep 65
I'll try to get those tightened down a bit more, just for peace of mind. |
04-07-2020, 10:26 AM | #7 | ||
Rep 65
CTS Turbo. Much cheaper option, but I'm not knocking the quality. It's just not a full carbon system like yours. |
04-07-2020, 12:50 PM | #8 |
Rep 2,285
Now that we are all quarantined you have time to take it off and drive it around. If the car feels faster, albeit quieter, then you know it's the Intake.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
04-07-2020, 01:11 PM | #9 |
Rep 65
04-07-2020, 01:15 PM | #10 | |
Rep 3,256
As other recommended maybe just to make sure everything is tight and seated correctly. Hopefully that'll solve it. |
Moflow2484.50 |
04-07-2020, 01:40 PM | #12 | ||
Rep 65
pz6193278.50 |
04-07-2020, 03:09 PM | #13 |
Rep 1,602
My old Celica All trac didn't have a BOV either, but one time a hose clamp wasn't tightened down properly and it made HUGE BOV esque sounds when i tried to drive it. It would also dump way too much fuel into the engine and slow everything down when it hit boost.
However, that was a hose clamp that was right before the intercooler on the high pressure side, not on the pre-turbo, low pressure side. |
04-07-2020, 03:37 PM | #14 | |
Rep 65
04-07-2020, 03:41 PM | #15 |
Rep 4,512
No - try throttle body adaption reset
Current '22 X3M LCI.. |
04-07-2020, 03:55 PM | #16 |
Rep 65
Do you happen to have the latest edition of "Throttle Body Adaption Reset for Dummies" that I could borrow?
04-07-2020, 04:09 PM | #17 | |
Rep 4,512
Megator517.50 |
04-07-2020, 04:10 PM | #18 | |
Rep 1,967
https://f87.bimmerpost.com/forums/sh....php?t=1669584 |
JMR138555.00 |
04-07-2020, 06:22 PM | #19 | ||
Rep 65
04-15-2020, 01:05 AM | #20 |
Rep 65
Update: I took off the turbo inlet pipe and discovered one of the T clamps around the silicone hose was busted. I replaced both T clamps and feel pretty confident with how tight I was able to get them. I also did that throttle response reset thing and took it for a spin the next day.
Here's the part where I'll just fall on my sword. It was pulling good but still felt a bit off from what I had initially felt w the car. Turns out I had programmed my M buttons incorrectly and what I thought was Sport + was just Sport. Once I put it in Sport + she was back on track. Sorry for the stupidity, but I'm glad to know it was user error! |
8
Madmat50.00 pz6193278.50 cptobvious2531.50 VFK_by_Midnight78.50 Moflow2484.50 natmad667.00 Poffman493.00 Teknolg4.50 |
05-24-2022, 12:27 AM | #21 |
Rep 9
Sorry to revive old thread but wondering if you kept the CTS intake and if so has there been any issues long term?
Previous Cars: 13 WRX Hatch | 14 BRZ | 20 WRX
