08-03-2016, 03:58 PM | #67 |
Rep 5,538
Indy shop here wanted $1200 for carbon cleanup in 335i lol. It's usually a bitch to find a honest, skilled mechanic. I have 1 number to a forum tech guy who does Lexus IS and N54/55 work, but I haven't used him yet.
08-03-2016, 04:19 PM | #69 |
Rep 1,481
I personally think the article errs on the extreme side of things, but it does have some points to take away as well... I've owned both japanese / german ONLY and so here is my small sample size opinion
In the last 20 years, my cars have been 1995 Nissan Maxima (168,000 miles, still own) -Only things I had to replace outside of regular maintenance was fuel injectors, CV axles, CV boots and control arm. Currently leaks oil, and suspension feels like it's a frail old lady. 2000 BMW 328i (90,000 miles, SOLD) -This car was a nightmare. 6+ window regulators broke, a/c sensor broke, intake / exhaust camshaft sensor faulty, water pump blew out at 60k, fan speed sensor broke, rear shock mounts torn, front control arms x 2, and some weird electronic issues.. I let this car go and was damn happy to rid this POS. 2003 Nissan Altima (100,000 miles, SOLD) No issues in 100k besides feeling like a cheap econobox and minor coolant leak that never leaked enough where I had to add some coolant. 2007 Nissan 350z (65,000 miles, SOLD) An axle had to be tightened and lubed down in 65k. Otherwise no issues.. 2007 BMW 550i (98,000 miles, still own) Replaced valve cover gasket, thermostat, mechatronic leak at 50k, and changed out something in my DME that was causing my car to not start / throw random transmission faults. (This is my daily now) 2008 Mercedes E550 (102,000, SOLD) Leaking valve cover gasket, leaking coolant by radiator at 102k. Nav LCD screen had broken pixels. Sold it before I fixed issues. 2008 Toyota Sienna - (105,000 miles, SOLD) not a single issue.. 2016 BMW M4 (current) - Delivered with adaptive headlights malfunctioning, and also my over the air updates don't work, as well as the apps. Will take it back to dealership on next oil change. I have to admit, on the german cars I was much more anal and changed things out. On the japanese cars (minus the 350z) I didn't really care as long as the car took me from A to B. On that note, I'd still say the japanese cars were cheaper and more reliable to own. My maxima I have been expecting it to die for the last 9 years (only maintenance I've done is give it cheapo oil changes @ 20-30 dollars each change) but it continues to run and won't die.. The engines on all my german cars have been fine though. But none of them were Ms.. |
08-03-2016, 05:06 PM | #70 |
Rep 5,538
^ I have nothing but good to say about pre 2000 Maximas. I had 95 and 98 and both were rock solid. 95 had 160k, 98 had 125k. Had some minor issues but also didn't care about any fluids besides engine oil that I replaced at 5k intervals for 20-30 bucks.
9krpmrx8808.00 |
08-03-2016, 05:17 PM | #71 |
Rep 1,481
agree..my battery died on it and I let it sit for 14 months.. swapped a battery in, started that bad boy up and after a few ticks from the engine from not starting up it went back to being smooth as butter and purring.. quite amazing actually for the amount of neglect it's taken
08-03-2016, 05:26 PM | #72 | |
Rep 3,256
The only issue my S2k really had was that it would eat timing chain tensioners every 25k miles or so. It just became a maintenance item for me. |
08-03-2016, 08:41 PM | #75 |
Rep 3,204
08-04-2016, 05:54 AM | #77 |
Rep 3,241
I find this discussion interesting. I think many of us were attracted to BMW because of how the company designed the cars to be a driver's car. Granted the cars aren't meant to compete against super/hyper cars but they're not your high fuel economy grocery getters either. When you push performance, you can expect some sort of "maintenance" with that package. If this specter of reliability is such an issue, the simple fix to this to hedge your bets and buy an extended warranty.
If you all want to know about temperamental and what it means to deal with higher than normal upkeep, try getting into a Ducati. The older engines in the family of the 748/749s had chrome plated rocker arms. The chrome would eventually wear/flake off causing the particles to float around in the engine not to mention the accelerated wear from the rocker arms contacting the cam lobes and the valve stem. This is/was a known problem and it's not a matter of if but when you had to get your top end rebuilt. That in addition to mandatory 7000 mile maintenance cycles to do valve lash adjustments and you have one high maintenance super model. Yet people still overlook these types of "issues" and flock to the brand in a cultish fever. |
08-04-2016, 07:07 AM | #78 |
Rep 2,665
Odd to me that the "BMW engine's are pieces of...." has turned into showing what one Honda engine could do that stopped production 8 years ago.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
SakhirM410784.50 desertman1232213.50 |
08-04-2016, 02:53 PM | #79 |
Chef
927
Rep 1,059
I stopped reading Jalop regularly for almost a year now. They have become an Amazon deal central for earning some affiliation cash. And who would pick and choose what messages you can post on their articles if they are open to opinion (they don't).
08-04-2016, 04:39 PM | #80 |
#buildnotbought
10855
Rep 4,893
Not that odd as bmw and honda were mainly the only ones that made high revving performance engines that where obtainable for mortals. (some exeptions excluded)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
08-05-2016, 04:35 AM | #81 |
piggy in the mirror
47
Rep 595
Trust me, modern Porsche engines also have their issues, however most of which are easily dealt with.
135i Coupe N55 PPK+JB4
X3 30d LCI |
08-05-2016, 05:50 AM | #82 | |
Rep 3,204
08-05-2016, 06:09 AM | #83 | |
Rep 828
Honda state 1000miles / litre of oil useage is perfectly fine too, so it's not just BMW. I've seen a fair few stock S2000's that have had blown engines (I've helped replace two for two friends... so that's 2 S2k's out of 9 (so translating to a 22% fail rate). Honda changed that valve retainers in the facelift because earlier ones failed with use. The cars themselves have issues - blown shock absorbers, siezed alignment bolts, catalytic converters that fall apart, crappy imobilizers and alarms, prematurely wearing CV cups... do I really need to continue?? ALL car companies end up having faults with their stuff - that's called engineering. Personally, I have no idea where this myth of German reliability came from... WW showed that German equipment whilst being advanced, was horribly unreliable (2days to replace a Panther gearbox anyone??). Tell you what though, I wouldn't swap my 335i for another S2000... |
08-05-2016, 06:40 AM | #84 |
Rep 130
I think every car has an Achilles heel. My CLK 350- radiator would fail, causing glycol to mix with transmission fluid. My G35, master and slave clutch cylinders would just give up. So you could be cruising at 60, go to downshift, and not be able to.
The only problem with BMW, is that they are expensive Achilles Heels. I had way more problems (quality wise) with my first car, an Acura CL, then my m3. Great thing on the CL, every thing was cheap. So repairs didn't hurt. M3, everything is in the 4 digits. On my m3, I had the rod bearings done. This car has 65k miles On my x3, I had my coolant system replaced. And repaired the AC evaporator. This car has 180k miles |
08-05-2016, 07:23 AM | #85 | |
Rep 3,995
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
08-05-2016, 07:41 AM | #86 | |
Rep 183
Point in case: https://hondaquality.wordpress.com/h...ows-otherwise/ https://www.consumeraffairs.com/auto...da-accord.html What about the transmission issue with the new crop of Acura sedans? Flip side, I know lots of people that own e92 m3s and have never even heard of the rod bearing issue because they don't feequent internet forums. It's the internet, of course you are going to hear people complaining. What did you expect? An engineer's perspective: when you push the limits of technology you should expect reliability issues. If we extend model cycles reliability numbers will increase, but then the forums will be full of posts bitching about the fact that it takes BMW eons to release a new car that is not simply a repeat of the last generation. Last edited by NeoGeo; 08-05-2016 at 07:47 AM.. |
08-05-2016, 08:41 AM | #87 |
Rep 1,232
This article is so stupid, BMWs are not built to be reliable, they are built to be a great driving performance experience, if you want reliability you should buy a Toyota or a Honda, which I had plenty and they are built to be reliable. Dumbest thing I have ever read, it's like writing an article explaining that Flip flops are the worst and completely unreliable for running
08-05-2016, 09:14 AM | #88 | |
Rep 2,665
My daily is now not a BMW partially because of reliability and my plan to keep it until 150k miles. Not the only reason to buy a car but anything that adds cost and irritation to the experience is something I considered. I would be interested in buying a used Ferrari (less than $100k) if the reliability, maintenance, repair weren't so crazy expensive and the "it wasn't built to be reliable", doesn't change my outlook on owning one.
