03-19-2022, 04:56 PM | #23 | |
Rep 7,431
The cam position sensor is sensitive down to fractions of a degree, there is no way it slips progressively over time if it slips it slips. There is no way to differentiate between a slip that occurs over time and one that occurs instantly by looking at scoring. But since the crank and cam angle sensors are so sensitive it can be reasonably assured that as soon as timing is slipping you will know about it, it won't occur over time slowly - if it breaks the coefficent of friction on the friction disk on the hub and slips it slips and permantly damages that washer meaning it will not be able to hold anymore, there are not partial slips.
An20Olives80.00 |
03-19-2022, 05:02 PM | #24 | ||
Rep 1,074
One thing that it could be is the JB4 may have hid the codes for so long because maybe it changes the parameters of everything? So maybe it was outside of tolerance and it never populated until recently. Either way it's in it's over with now I can grab a set of turbos. I turned it up today finally since I got the crankhub put in. She hauls ass
Instagram: M2_Medusa
Moflow2484.50 |
03-19-2022, 05:34 PM | #25 | |
Rep 7,431
Yes every has a tolerance range, but the angle sensors are good down to .1 of a degree so that's very very very accurate, and any slip will be caught.
03-19-2022, 05:56 PM | #26 | |
Rep 23
F87source7253.50 |
03-20-2022, 01:06 PM | #27 |
Rep 1,074
Another data point, I been thinking about how I have been driving the car and wanna unload as much info as possible.
I may not have taken it past 7000 rpm when accelerating however it dawned on me that I always manually downshift the car and many times the car would downshift to about 5-6k rpm a lot. I presume this is reverse torque and a main accelerant of the spun hubs. This common practice of mine could have been the accelerator of my spun hub. I can't confirm it however I'm happy to share this data with everyone
Moflow2484.50 shadow135i40.00 |
03-20-2022, 01:08 PM | #28 | ||
Rep 1,074
03-20-2022, 01:11 PM | #29 |
Rep 81
Drives: M2 Competition 6MT
I saw people running multiple trackdays with a stage 1 tune and nothing happened. This is so weird I can’t really comprehend it. Maybe running a tune with a progresive torque curve helps? I don’t know. Anyway I’m glad your car is running happily .
M2_MEDUSA664.00 |
03-20-2022, 01:24 PM | #30 |
Rep 81
I believe the BMW M4 GT4 runs an oem crankhub and runs laps after laps for hours and nothing happens. Weird .
prompt292.00 An20Olives80.00 |
03-23-2022, 09:33 PM | #34 |
Rep 6,637
03-23-2022, 09:53 PM | #35 | |
Food Critic
1086
Rep 1,015
I'm in Korea, track with a ton of S55 folks, and no spun hubs. Nobody even does crank hub fixes here either. All those N-Ring cars in Europe? Vast majority don't do it either.
03-23-2022, 10:00 PM | #36 |
Rep 7,299
I still am not sure what to think. Other than highly tuned cars, this does seem like a failure that happens early in the life of stock and lightly tuned cars. Perhaps most of the failures are destined from the beginning and would happen tuned or not. We have seen this on low mileage stock S55s. It doesn't feel like the rate is any lower on M2C than F8x ZCP or the CS models. Perhaps it's not related to the power output until you hit extremes. No idea really, just a theory and we'll never have the data clear enough to find out.
Is M GmbH really this impenetrable? You would think that an insider would have leaked the root cause years ago. |
03-23-2022, 11:54 PM | #37 |
Rep 81
No I wouldn’t . Stock cars who spun their hub did so because of factory error. No other possible reason because every case of stock crankhub spin I’ve seen was during break in miles or right after ( basically very low mileage ) . I’d probably go for a low torque tune as well with the stock crankhub. There are more people that didn’t spin theirs than the ones who did on a tune from what I’ve seen. Just my take on it .
03-23-2022, 11:58 PM | #38 |
Rep 81
There is some guy with a BMW M2C on youtube who has been running a stage 1 on stock crankhub for a few months . He tracks his car at the nurburgring and he doesn’t have any issues . Each with their luck. I’ve seen M4 ‘s with 650hp with no issues as well .
03-24-2022, 06:18 PM | #40 |
Rep 1,074
Hey guys yeah the spun crank hub issue may or may not happen immediately but if your tuned it's a ticking time bomb. I too have seen my fair share of 550-600whp s55 motors with no spun hub see abuse day in and day out on the track. Some of those cars eventually spun… blues clues M3 for example. It may be ripping on the track now but soon the fun comes to an end.
When you tune the vehicle whether you like it or not you are going outside of factory tolerance. When your outside of that tolerance bad things happen. This is unfortunately the weak point. These are strong motors and can handle upwards of 800hp before rods and pistons needs addressed. These are beautiful cars when tuned and I hope everyone experiences the level of power these motors can produce with a strong tune. Just do it right. And do it with a crankhub. I myself denied it and always said " it's such a small percentage, chances are slim " I was wrong. If your stock and under warranty don't worry about it. If your tuned, it's a matter of time and hopefully you sell the car before it's your turn to face the music. Do your crankhub and forget it.
03-25-2022, 05:07 AM | #41 |
Rep 414
03-25-2022, 05:14 AM | #42 | |
Rep 414
That is literally the biggest scam in the S55 aftermarket industry. Does absolutely nothing to hinder a spin. The one piece crank hub is all you need |
Silverlining_m21736.00 stefan2354.00 |
03-25-2022, 12:56 PM | #43 | ||
Rep 1,074
$100 and 45 min of work is far from a scam. But keep believing that By the way all the data in the market proved your claim completely false! Not a single spun hub has ever beeen reported outside of a moneyshift when crank bolt capture has been installed under 600/600. Data proves you completely incorrect.
An20Olives80.00 |
03-25-2022, 01:02 PM | #44 | |
Rep 162
I take issue with saying "it's a matter of time". You simply don't know that with any certainty and what little data is available contradicts this. Truth is these motors don't seem to be failing by the thousands despite how many copies of BM3, JB4, etc are being used in the open market. Your statements about this issue are colored by your recent experience. In simplest terms it's what is known as reverse survivorship bias. A true pro forma to evaluate the cost / benefit of a clutch hub upgrade would need to evaluate how often they spin, how often each clutch hub upgrade still fails, what the average and range of the cost of repair of a spin is (timing, hub replace, full motor, etc), and the cost of the upgrade. Of course you'd need to evaluate the various options available to figure out if some or any of them were really worth it based on how much they prevented (or exacerbated) the damage. And yes, there is some thought that the damage is more catastrophic when an "upgrade" fails violently rather than a slight slip of the stock hub. Most of that data is unavailable to us so really this is a case study. Purely anecdotal and not actionable to the S55 motor writ large. Again, sucks that it happened to you but for me it's a small risk to begin with and a lot of marketing hype based on what *appears* to be a marginal amount of failures of the S55. The problem is that if you are one of the unlucky few it hurts bad. I just don't know that the expensive "fix" is really good insurance per dollar or not. I guess if it happens to mine it will be 100% a problem, and if it doesn't then it's 100% a win. Roll the dice… |
captain slowly725.50 |
