12-14-2020, 01:56 PM | #331 | |
Rep 4,516
I know of a couple of folk who've had their kit refreshed/rebuilt by Cornering Force in Harrogate, they're a certified KW rebuilder ✅
Current '22 X3M LCI.. |
lengrenjt19.50 |
12-20-2020, 08:50 PM | #332 |
Remove Before Flight
6830
Rep 1,611
Query:
On a 2020 M2C with the following combination: - MP coilovers, set to BMW's "Street" recommendations (~20mm drop, I think?) - Stock 788 wheels (Front: 19x9 ET+29, Rear: 19x10 ET+40) - Michelin Pilot Sport 4S tires Front: 255/35/19, Rear: 275/35/19 (+1 from stock) What size of spacers (front/rear) would work to allow for NO rubbing and NO poke out beyond the fender walls? TIA. R. |
12-21-2020, 10:52 AM | #333 | ||
20
Rep 77
Have done 300 miles on them already. Still not properly aligned in the rear, fronts should still have OEM alignment but the drop might have changed things... 1. Running 0.25" drop all around, based on the separation of the adjustable plates being 0.75" apart. Rears definitely dropped more than the fronts, gonna have to adjust for that. But from eye balling looks like rears went down 0.5" and fronts 0.25". 2. For sure more comfort. The bumps on the road are much smoother and the comfort in longer distance drives is improved a lot. 3. More compliant. When punching through entrance/exits on highway the bumps are less bouncy in the rear. Soaks it in much better. Notes: no issues with sqeaking, only happened in the very beginning but that's gone. No complaints at all really. Only thing weird is the rear springs are kinda slanted but KW HAS and MSS pics show this is normal so oh well, functions fine. Score 9/10 Bang for buck if you purchased at a discount like I did. Full value 900$ I'd lower the rating a bit but still this is the route to go if you want cosmetic enhancement, some comfort, and cost efficiency. |
12-21-2020, 10:58 AM | #334 | |
Rep 622
M2C_jondagger19.50 |
12-21-2020, 01:38 PM | #335 |
844
Rep 1,962
Yes. It would be even better if he posted it on an MSS Springs thread. This one for example:
https://f87.bimmerpost.com/forums/sh...&highlight=mss Or - for maximum impact - start a new one devoted to how wonderful the customer service of his supplier is. Last edited by M Fifty; 12-21-2020 at 01:40 PM.. Reason: Where to stick it. |
12-22-2020, 08:49 AM | #336 |
381
Rep 731
What was your impression of comparing the three different suspensions? You did't mention how the Ohlins compared.
At a Point above 7,000 RPM.
12-22-2020, 11:23 AM | #337 | |
381
Rep 731
Spring Rates
12-22-2020, 11:31 AM | #338 | |
381
Rep 731
12-22-2020, 11:44 AM | #339 | |
Rep 2,700
chief1richard381.00 |
12-22-2020, 01:16 PM | #340 | |
6637
Rep 4,145
Drives: '18 M2 6MT
12-23-2020, 06:55 AM | #341 |
Rep 108
i track a crap load.... i have the BMW M2 Comp... and on our australian roads the OEM suspension is jittery as hell and just way to stiff for day to day driving.... i also took my stock BMW M2C ... down to my race track and posted a lap time.... (im use to the track and i drive it alot) got a reference lap... put the MPC on... and a set of Semi Slicks and knocked off 4 seconds a lap off my stock time i posted in the car stock... set up correctly the MPC are a great coil over.. that has the benefit of being covered under BMW warranty. only worry is that they are KW rebrands.. and i know the KW are susceptible to shock leaks....
PLF693767.50 Drifter2090909.50 |
12-23-2020, 07:50 AM | #342 | |
Rep 2,700
If I would do it again I would probably go this way. I will have my suspension out for the 4th time this winter and I really hope this time it's going to meet my expectations cause I'm starting to have some taughts about parting-out and going to a more track ready platform..
12-23-2020, 03:31 PM | #343 | |
Rep 14
Would like someone running the setup to confirm this. Thanks in advance! |
12-26-2020, 05:40 PM | #344 | |
Rep 52
12-26-2020, 06:21 PM | #345 | ||
6830
Rep 1,611
I thought the 255/35/19 on stock wheels was "safe"? Or is it the MP suspension that makes this difficult and causes rubbing? If so, what's the solution? TIA—
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
12-27-2020, 01:06 PM | #346 | |
Rep 2,067
I have 12 up front and it is not a perfect/flush fit and it does in fact rub on 3/4 lock with mp4s in stock sizes It's more of a fender liner brushing sound than a rub. I'm sure a 10mm up front would be brush free It's kind of unfortunate in my opinion if I want the perfect fitment with stock wheels (15 up front) I'll have to modify the fender liner. Hope that helps. |
12-27-2020, 03:46 PM | #347 |
381
Rep 731
M Performance Suspension
Am about to switch over my Stock Suspension to M Performance with Vorshlag Camber Plates. When ordering the Vorshlag Plates you need to know the diameter of the Damper, which its says is either 12 or 14 MM, for the M Performance Dampers. Cannot find this info anywhere. Does anyone know what they are? I would measure them but do not have them yet.
12-27-2020, 06:13 PM | #348 | |
Rep 52
It really depends on the tire in use. 255/35R19 Conti Winter TS830P for example are rubbing. 245/35R19 Michelin Winter PA4 are also rubbing (yes, even as 245! They are extremely wide). 245/35R19 Michelin Summer PSS are of course not rubbing (stock size). Above results always based on stock offset and rim sizes. It does not really depend on the coilovers.. |
12-27-2020, 07:10 PM | #349 |
Rep 658
I have constant noise with my M Perfomance coilovers when going over bumps. The front and the rear axle creak all the time when I go over speed bumps or potholes regardless of their size.
It is a bit annoying to hear this sound all the time. The noise is not very load but it is distinct. Have anyone experienced same issue? |
12-27-2020, 10:17 PM | #350 | ||
Rep 1,078
12-28-2020, 03:22 AM | #351 | |
844
Rep 1,962
12-28-2020, 09:45 AM | #352 |
381
Rep 731
MP Coilover Fitment
After reading this thread I am having second thoughts of ordering MP Coilovers. Am I correct that after installing them with the recommended 15mm drop, that my Stock Wheels with +1 sizing (255/35/19, 275/35/19, will rub? If so I may have to go with just Camber Plates.
